Question about Ovens
E6 F2 Error Code
Have not been able to find what this code means.
  • 3 more comments
  • VegasDblD Dec 31, 2007
    It is a Whirlpool RBD275PDQ10 gas double oven. Thank you.
    Yes. I've done this and the error code returns. Where can I get information on how to do the repair myself? I've come across several sites that have the keypad for sale, any you prefer? Thanks
  • slatts33 Feb 28, 2008
    We had the E6 F2 error code come up and the lighting on the control panel phases in and out. How do we fix it.
    model # GBD307 - Built in double conventional oven
  • davidmary484 Jun 22, 2008
    Have an error code E6 F2 error code, plus the control lock is on the display. What do we do?
How do I order it from them? Am I ordering the instructions from them?
Posted on Jan 02, 2008
    President:
  • 1,314 Answers
Need your mod# and brand
Posted on Dec 30, 2007
  • 2 more comments
  • robert samples Dec 31, 2007
    c
    Press CANCEL. If error code returns after 60 sec., replace keypad
    cancel key drive line open
    ill give info on that tomorrow ok how to replace eoc
  • robert samples Jan 01, 2008
    i havnt forgotton you just busy
  • robert samples Jan 02, 2008
    i think id order it from the fixya web site to help them keep the sit open when you get it reply to me and we will do it togeather ok that way we will both be on line at the same time
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Error code E6F2
i got a tech sheet for your range accept this message as a fix ya and e mail me at b4829@yahoo.com and ill send it back as an attachment just say f2 e6 code
May 24, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
458 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
