Question about Samsung SyncMaster 720N Monitor
On screen controls have a mind of their own
My samsung syncmaster 720n has been with me for the past 4 months but 2 days ago the brightness control won't come off the screen and the monitor itsekf won't run off when i press the switch. so technically the controls aren't working. can you help me on this problem? thanks!
  • Whipple821 Mar 02, 2008
    I had one that did the same. I contacted Samsung and they exchanged it for another repaired one. It is doing the same thing. I haven't contacted them again yet. This one also goes blank and then back on.
    Novelist:
  • 188 Answers
The buttons are stuck - If the screen is out of warranty then i would take it apart and see if he buttons can be unplugged or cleaned up.
If in warranty Samsung is excellent with repair service. - Depending on the model LCD its either 1 or 3 years warranty.
Posted on Dec 31, 2007
Brightness bar stays in the center of my screen Samsung SyncMaster 731N
I'm Adam and i'm a computer-technicien!
I should do these 2 things do hide this brightness bar:
-You can click the MENU button again!
-You can simply disconnect the power-cable from the monitor and
let it unplugged for like...10-15 seconds!
-You can remove the button with a screw-driver and take the
little plastic on the second button.
If this all doesn't work...
I can recommend you to send a email to SAMSUNG with this info:
-Name:
-Date when you bought this product:
-When did this start:
-And your CPU information:
If this all doesn't help...
You ned to install a driver called 'Syncmaster 720n/730n driver'!
Thank you,
May 25, 2011 | Samsung SyncMaster 720N/731N
HOW TO DELETE BRIGHTNESS BOX FROM MONITOR ON SAMSUNG SYNCMASTER 720n
If your trying to get out from the brightness option. Please follow this steps...
Go and click this manual, then at the left side of the manual look option that says for "Adjusting your monitor" then look for user controls.
I hope it helps you a lot :)
Feb 03, 2011 | Samsung SyncMaster 720N Monitor
Have samsung syncmaster 720n monitor. adjustment menu blinks on/off. how to stop?
Trying the hold down power button for count of ten (did count of twenty just to make sure) didn't work. Menu came back up. Will try unplugging control chip next (this fix doesn't make sense to me ) will see if monitor will work without chip>
Aug 13, 2010 | Samsung SyncMaster 720N Monitor
Probably not only because I found several forums and the same claim as is my case .. initially function to adjust the brightness automatically .. 100% ... like I keep the button pressed continuously .....
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=720N
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Samsung SyncMaster 720N Monitor
Syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Sep 01, 2009 | Samsung SyncMaster 720N Monitor
Samsung SyncMaster 720N ...
Peace.
Aug 01, 2009 | Samsung SyncMaster 720N Monitor
The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
May 27, 2009 | Samsung SyncMaster 720N Monitor
Picture size problem
click start,control panel,display,settings and set your screen resolution to what you need
May 23, 2009 | Samsung Syncmaster 17" 720N Monitor
Samsung SyncMaster 720N Monitor Logo
576 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
