Question about Microsoft Xbox 360 Console
My console is beginning to suck
My 360 randomly refuses to read 360 discs...shows the notice to play it in a 360 plays music cd's and dvd's no discs are kept in good will even show the notice on new discs..i have to keep ejecting til it decides to read it....please advise ....gingerrambo
  • 54 Answers
Re: my console is beginning to suck
Install a new dvd drive.
Posted on Feb 12, 2008
    Problem Solver:
  • 8 Answers
You can buy a disk cleaning set or you can take a damp cloth and wash the back of the disk, also make sure your console is sitting so that the disc insert is sitting horizontal
Posted on Jan 04, 2008
0 characters
3 Points
Will the discs clean
It was an issue before, around 2009. The console it self wont play any disc, XBOX came up with replacing the cd drive of the console but its not the simplest way to solve the issue. As part of the escalation department then, we found out that just simply using the usb port of the console to play music or at least a media was read by the console, you can resolve the issue.
1. Plug a USB flask drive or any mobile phone via USB to the xbox.2. Play any music from the external drive (flask drive or mobile phone that is connected via USB to the xbox)3. once music is playing, insert a disc in the cd drive.4. The xbox will read the cd this time for its currently acknowledging the media part of the connection5. Then you are good to go..
Thank you for choosing you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 03, 2011 | Microsoft Xbox 360 Console
Xbox 360 will not read games or dvd's
Try to insert a straighten paper pin into the hole under the tray if still no go You have to open the cover and take the cd out.
Sep 01, 2008 | Microsoft Xbox 360 Console
Wht does it mean when you put a xbox 360 gme in the console and it says play dvd and sometimesa wont read the game discs
When it says play dvd, it just randomly doesn't recognize that it's a game. Press A and you'll enter the game.
When it doesn't recognize the disc all together, I'd suggest cleaning the disc with an anti-static cloth then putting the disc back in.
Mar 05, 2011 | Microsoft Xbox 360 Console
Xbox wont read any of our games, but the games will read on friends. We can listen to music or use our microsoft points to watch movies.
Sounds like an issue with the optical drive. I would suggest trying a different type of disc in the drive ( I think they can play music CD's as well as DVD discs). You might just need a replacement drive for it.
Dec 05, 2010 | Microsoft Xbox 360 Console
The xbox 360 will not read game discs or give me the option to play the game it only gives me the option to play a cd
By the problem you have described, i beleive you have a modded Xbox 360 used to play copied games, if yes you need to check what game are you playing.
If it is a latest game, then you would require a Wave 4 patch to play copied games on a modded Xbox 360, you can google on the web to find out the list of games that require wave 4 patch to run before you play the game on Xbox 360
What you need to do is first burn the Wave 4 patch on a Dual Layer DVD and load the game disc first and you would see "play CD" option, now take out the game disc and enter the Wave 4 patch disc you just burned and again you would see "play CD" option.
DO NOT PLAY the CD, just take it out again and re-insert your copied game CD in your Xbox 360 and you should be good to go.
Feb 27, 2010 | Microsoft Xbox 360 Console
My xbox 360 does not read ANY discs
Does it play music cd's? Your laser needs to be replaced.
Feb 16, 2010 | Microsoft Xbox 360 Console
Random unreadable disc errors
I had the same problem but i sent it in. They said it was the eye reader error. Or the thing that reads the disc. Try buying a brand new game and try playing it. Alot of times when i have disc read errors i put the disc in where the xbox 360 part at the top goes in facing the xbox. Try that to see if it helps.
Mar 15, 2009 | Microsoft Xbox 360 Console
Will not play 360 discs on my xbox360
same thing happened to me. the disk is basically garbage. there must be a scratch or chip on the cd thats y it wont play.
Jan 19, 2009 | Microsoft Xbox 360 Console
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
X box 360
it maybe scratched or then lens may be dirty or i can recommend to take it to a speiacl shop that fixes things.
Jan 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
