Question about Kenwood 105VR
How do I get my Dual turntable to work with the 105VR?
I tried to hook my recently-repaired Dual turntable to the 105VR using the phone input without luck. There is very little sound or signal, even though the CD and cassette players work without a problem. The Dual was great with the Harmon Kardon receiver/amp.
Any help would be appreciated.
Thanks.
IowaLen
  • IowaLen Dec 30, 2007
    That is "phono" input. Oops.
    Thanks for the help.
    IowaLen
techman
  • 3130 Answers
SOURCE: Receiver only works in Stereo Mode and won't allow use of subwoofer
That sounds about right, about the audio processor IC most likly being the culprit. To repair this, a test tone should be inserted into the unit, and using an ocilliscope to trace the audio waveform through the circuit, and see where it craps out. There could also be a regulator componet from the power supply that is going out after start up and becoming intermittant. Sorry to say in this case there is no wasyy fix unless you have a schematic and the proper equipment. Time to take the unit into the reciver repair Place. Good Luck
Posted on Jul 23, 2006
SOURCE: Subwoofer not working
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
Posted on Jan 12, 2007
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
tech48
  • 624 Answers
SOURCE: receiver works with digital signal input jack only.
Are you talking about the 6 channel input with all RCA jacks? Please explain a little better, it is very hard to know how you have it connected without a very good description since I can not put my eyes on it. You may need to check the settings, it may have the rears muted. More information from you will help me to be able to help you.
Posted on Feb 06, 2009
SOURCE: Harmon Kardon reel to reel tape player
I have a Harmon Kardon TD-3 that I'm looking to sell. It's not in its original cabinet, but in a smaller box that takes up less space.
Posted on Oct 19, 2009
How do you plug an ipod into a Kenwood 105vr receiver?
Use a headphone to RCA/phono cable and plug it in to a spare audio input on the amp. Set the MP3 volume to about 50%.
Sep 08, 2014 | Kenwood 105VR Video Surround Sound Stereo...
Pioneer VSX-D810X
Depends on the turntable. Your turntable would need to have a built-in preamp in order to work.
Apr 23, 2013 | Audio Players & Recorders
How to hook up a turntable to a pioneer vsx-1019
receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
May 02, 2011 | Audio Players & Recorders
I can't hook up a turntable without getting bad Feedback
Sounds like the table is to close to the speakers!
Also if you boost the bass and/or loudness button
on specially if the speakers are "big" with large woofers! Try also extra "feet" below the table for more isolation can help!
Dec 22, 2009 | Onkyo TX-8511 Receiver
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Jul 21, 2009 | Audio Players & Recorders
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Hooking up Turntable to Yahama HTR-5660
you have to have a pre amp, or an old reciever with a phono input.
you dont have to use the aux input, the cd or md-cdr inputs will be fine, but you do need that preamp for that reciever
Nov 29, 2008 | Yamaha Audio Players & Recorders
How to hook up my turntable to my RCA home entertainment system
http://www.htfr.com/more-info/?catno=MR155277.
please buy the item above -----connect your turntable to input and take the output and connect it in line in in receiver.
Aug 11, 2008 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
37 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
