Question about Magic Chef CGR3742 Gas Kitchen Range
Magic Chef Gas Range
Alarm won't stop. Code reads F1. How do we stop alarm?
  • Anonymous May 01, 2008
    Is there any way to manually stop the code from continuously appearing, or turn off the oven without unplugging it?
  • Anonymous Oct 04, 2008
    when oven on for about 5 minutes flashing f1 code comes on and oven turns off
    President:
  • 1,314 Answers
Hit cancel
Posted on Dec 30, 2007
  • donna450 Feb 04, 2011
    Duh...Doncha think the average person is bright enough to try the cancel button? That is not the solution, as the oven starts beeping again a few seconds later, no matter how many times or how long you press the stop/cancel button.
What do i do about an F1 alarm that won't quit??????
Hello there:
this annoying alarm and the f1 code is reffering to the
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, you will need to remove the back panel that houses the electronic control unit then disconnect ribbon strip. going to it and retry the oven If NO fault code, replace membrane, otherwise replace board
Oct 05, 2010 | Magic Chef CER1115AA Electric Kitchen...
Alarm ringing, F1 code
Following may be the cause
1. .Watchdog on board
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board.
Thank You
Sep 03, 2010 | Magic Chef 9122 Gas Single Oven
Gas range beeps non stop and the panel shows F1
Hi bobctsai,
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Apr 23, 2010 | Magic Chef 31000 Gas Kitchen Range
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
The alarm get of and F1 on displey
Your electronic oven control(EOC) is bad and must be replaced.
Aug 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Intermittent alarm
pull your range out there is a tech sheet on the back that will tell you what the reason for the f1 code is. you can go from there.
Jan 03, 2009 | Magic Chef Kitchen Ranges
F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
Dec 09, 2008 | Magic Chef 31100 Gas Kitchen Range
Magic chef beeping
You need to replace the touchpad. I'm just getting ready to replace mine for the second time in 14 years. A bit pricey but not a hard repair to make.
An appliance repairman told me that it's possible to peel the old pad off and carefully fish the connecting wire out to the point where it plugs together. This would save removing the burners and the stovetop I'm going to give it a try when mine arrives
Mar 01, 2008 | Magic Chef 31000 Gas Kitchen Range
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Magic Chef CGR3742 Gas Kitchen Range Logo
338 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
