Question about Packard Bell Modems
New parkard bell pc
Just bought new parkard bell pc with it they gave us a 22in monitor but it was a acer every time we go to set it up it is coming up no signal then it says encountered a problem and shuts down
0 characters
1 Points
My internet goes down randomly. I don't know if it my modem or my provider. Any suggestions? I am using an Efficient Networks Speedstream 5100 modem and an D-Link WBR 1310 wireless router.
Are you using wired ports on the router or wireless?
If you are using wireless, do you have a cordless phone nearby and does the use of it coincide with the loss of internet? Have you tried switching to a wired connection for a short while to see if you are having the same problem? Could be intereference issues with your wireless signal. When you look at the available wireless networks, are there more than one? Could be that your PC/laptop is trying to connect to someone else's wireless if their signal strength is stronger.
If you are using a wired connection on the wireless router and still losing connectivity, try a network connection monitoring tool such as WhatsUpGold (free to try). Have it set up to monitor your PC's gateway address (which should be your wireless router) and some other internet site (Google, Yahoo, etc). If your router connection never drops, but the internet site does, good chance that it's your provider.
Make sure you have the latest drivers for your network device (wired or wireless) and the latest version of firmware for your D-Link. Buggy drivers and firmware can definitely cause flakiness.
Aug 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
you will need to purchase an adapter from your isp to use with your new notebook.
A modem or wifi router will still need to be connected to an ISP service.
Apr 17, 2009 | Modems
Internet green light always in and out
call ur ISP ur singnal is droping they will send a tech to inspect the lines
make sure u dont have ur modem on the grown near speakers monitor or on PC tower make EMI electro magnetic interferance
will make you have intermittent signal but probably not the case
95% sure its a line issue
rate my service please !
Apr 11, 2009 | 2wire (1000-000057-000) Modem
Dsl sync
The question I have is,
1. Did you have sync previously and it has suddenly stopped working?
2. Is this new a new DSL activation of service to your address and has not achieved sync yet?
for 1.
The most common issue is usually a recent change within the telephone environment or equipment at your address, does any of the following fit your scenario: You recently moved your DSL equipment to another room, you have bought a new phone, answer machine, Fax machine, Sky television subscription, a monitored security alarm service has been installed at your address or health monitoring equipment has been installed or an unlikely, lightening strike or power outage has occurred around the same time as sync was lost.
Any of the previous changes may have altered the way DSL signal is being filtered or split from your standard home phone signal, all telephone line using devices except for the modem/router will need to have its own DSL filter, if security or health monitoring was installed you will need to contact your internet provider and request a line splitter installation (this can be at some cost to the user, so don't forget to check what a local electrician can do this same job for)
DSL Filters can also be very susceptible to problems after power surge/failure or lightening strike at your address. Or if you have recently moved your DSL equipment, please double check the way you have setup the filter and cables at its new location.
The only test required to verify the issue is not at your address is known as an ISOLATION TEST. The router must be checked in a Phone signal free environment, please remove all phone cables from all jack-points within your premis and plug in only your router, without a filter, you should also test your router across all the jackpoints at your address if the first phone-jack you try fails) If we got lucky, you now have sync and the problem lies with one of your phone line using devices or the filter that it is using, start plugging each device back into the phone circuit one device at a time, with a filter and check to see if the router has lost sync after each device is plugged back in until you are able to identify the problem device, filter or jack-point.
for 2.
Follow the directions exactly as above and if no problem devices, filters or jack-points are found, then ISOLATE your router again and call your ISP provider and request firstly a "port reset" for your DSL port, this should be achieved within a 24Hr period, some are able to do this within 20min of your call, if sync will still not come up it is time for the ISP or service provider to send out a technician to verify the issue is not at the port, cabinet or exchange, this may take some providers up to 5 days to achieve.
Some last thoughts,
Dont rule out the possibilty of the Phone cable used for the router has failed (test the cable on a working home phone to verify it is still working)
or you may have bought an extension cable for your router, the length of Ph cable between your router and the jack-point can be no longer than 5meters before DSL signal fade can start to occur, the router will work at its best with a 15cm-30cm Phone cable, the 1meter cable usually supplied is fine.
Also, do check the jackpoints that you are NOT using at this premis (rare occasions have found me resolving sync issues because the vaccum cleaner has taken out one of your unused jack-points under the bed, in the spare room or the neighbours visiting toddler has tried to plug in a jam sandwhich or even a small plastic toy of some sort into an unused jackpoint)
If you are able, do check that your router can get sync and connect Ok at an address where DSL signal and Sync is currently known to be working.
If you have just moved to this address and your property is over 40-50Yrs old, you may want to check with the phone line provider to see if "line insulators" have ever been installed previously to resolve line noise issues, ageing line insulators will corrupt your DSL signal especially on the high humidity days.
I realise this must seem quite broad and intensive, this testing is intended to rule out any possibility of the issue being internal to your address (as we all know TELCO technicians are all too eager to hit you with unexpected maintenance charges if the issue is found to be internal to your property, as opposed to external)
Hope this gets you closer to identifying the source of your DSL sync issues, if you are like the many DSL subscribers out there, you cant stand to be without your high speed internet for more than two minutes either.
Happy hunting.
Nov 14, 2008 | Modems
Speadsream 5200 E240
modems are now shipped with the Hardware firewall turned on low to block things,and also Telnet..
Turned it off and then it should also all fixed.
there is methods of hacking this unit as well
Step 1: you have to make sure your IP is set to
Step 2: Go to »···retain=f and set "All Items" under "Profile Configuration Access" click next and choose "Do not require admin login"
Step2: Go to »···retain=f and do the same thing, except type as your "Constant Profile IP Address".
(if everything went ok, you should now see the new configuration page)
From here, you have to access every configuration page manually.
Here they are:
» - DHCP
» - Dynamic DNS (what francoisr wanted)
» - IP Passthru
» - Update firmware
» - RAS config
» - Port forwarding
» - DMZ Config
» - Firewall Config
» - NAT/NAPT Configuration
» - Host Configuration
» - UPNP Configuration
» - RIP Configuration - Time Server Configuration
» - Firewall Config Wizard
» - FW Attack Detection System
» - Firewall Snooze Control
» - Gateway Server Port Config
hope that helps
Aug 02, 2008 | Efficient Networks SpeedStream 5200 Modem
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Modems
2wire modem not broadcasting wireless signal
are the lights on the modem detecting any connection? is your line still programmed for broadband? if your modem is connected at the phone exchange and the connection is at your house and all and none of your computers can connect to the net, not even the primary computer and you have called your technical team for broadband (can be company policy sometimes to call them) you may need a replacement modem. Tech support should do a ping and other tech things to try to get you connected. you may have a faulty modem which if it is new then you should be entitled to a warranty replacement. if it is a simple setting on your computer they should be able to resolve this, i know that when vista first came out there were a lot of support issues with bband providers being able to support the users.
Nov 22, 2007 | 2wire (1000-000057-000) Modem
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Oct 03, 2007 | Modems
New out of the box modem not working
HI, please let me know are you looking for the modem installation process? If so , please let me know the make and model of the modem you bought.
Sep 27, 2007 | Toshiba PCX2200 (pcx2200key) Modem
Modems Logo
20 people viewed this question
Top Packard Bell Modems Experts
Brian Sullivan
Brian Sullivan
Are you a Packard Bell Modem Expert? Answer questions, earn points and help others
