Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
Samsung 17" Flat Panel Monitor - Streaks
I bought a Samsung monitor through CompUSA in August of this year (2007), and it was fine until a month or so ago - now, after random amounts of time, streaks will apear that make it look as if anything being displayed is moving by really fast to the left.
They go away if I lean the monitor forward and wiggle it a bit, then put it back.
I've never heard of anything like this and could not find anything online about it. Any ideas?
  • 2 more comments
  • Anonymous Apr 29, 2008
    Interesting. I was just searching for this problem and found your note. I had not tried tilting the monitor. It worked!
    I guess my next question is how long does it take before the streaks return?
  • aaclaude Sep 20, 2008
    Exact same issue, although my monitor is a bigger model. Same work around.
  • Anonymous Jan 22, 2009
    Same problem with a 22 inch monitor, after about two years. Tilt trick worked. Tilted down, then up then back into position, and the streaks are gone. Go figure. I was afraid the problem was my video card.
  • zebus Jan 26, 2009
    I have the same problem on my 17 inch model. The solutions offered work but only temporarly. Does anybody have a perminant solution?
Unplug the pin connector from the back of the monitor. Re connect, tighten securly using a screw driver. Worked for me.
Posted on Feb 02, 2009
I had this same problem with my ViewSonic LCD monitor. I tried turning the monitor off from the button on the front, and tried changing the settings for the monitor. That didn't help. But then I unplugged it from the power source, and the streaks immediately vanished!
Posted on Dec 11, 2008
17" flat screen upper half is dark until "thumped"!
The inverter board that controls the lighting on the screen is dying. since its a 5 year old monitor and only a 17 inch. the cost to repair is greater than the cost of buying a new one. unless you know how to replace the part yourself. I think its best to just buy a new monitor
May 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Picture not filling monitor screen
what is your sceen resolution set at on your laptop. try adjusting them and see if that works.
Nov 01, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Samsung monitor has "streaks"
LaurieEm posted a solution which seems to work for me (in addition to some other stuff, read my problem description) for this here
Try re-plugging your LCD monitor's VGA connection. It may be a case of corrosion on the pins or bad puggin of the cable. The problem is also reduced by using compressed air to blow out the cicuitry in the back of the monitor to remove dust. Both of these seem to work, and if you can't solve the problem totally with one, try the other one as well.
Mar 06, 2008 | Samsung 931BF 17" LCD Monitor
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
410 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
