Question about SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260
I have a SanDisk Sansa e260 - where are the instructions for operating the unit?
  • 1 more comment
  • stampede16 Dec 31, 2007
    i have my 260 connected thru the usb port but this is all that displays on the screen(connected) pls help
  • boogmister Jan 01, 2008
    how do you you delete songs from e260?
  • scottc59 Jan 02, 2008
    The "solution" to the question I posted is absolutely WORTHLESS - I'd rather you didn't attempt to post a solution when you simply don't have a solution and then misrepresent it as such - quite dishonest.
    Problem Solver:
  • 5 Answers
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Posted on Jan 02, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
I require a French manual for the Sansa 4GB Fuzion MP3
Download the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Dec 29, 2009 | SanDisk Sansa e260 MP3 Player
I Bought the e260 but no instructions. how do you load and unload songs?
The is the Sansa software/Updates/Manuals for all sansa players...Follow The Instructions After you save then run or Run.....
Nov 01, 2009 | SanDisk Sansa e260 MP3 Player
I connected my SanDisk Sansa e260 Mp3 player and says connected
You can copy the music from the computer to the Player My Computer\Sansa e200...\music or to a micro sd-card.
Download user manual SanDisk e200 series.
Just pick the language you need.
Jun 13, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 player not recognized by window
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) . download and install Copy and paste click run to install follow instructions make sure your sansa is in msc usb mod in the settings in the sansa
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
I think that my sansa e260 have a virus, which could be the solution?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 isues.
Hiya, you can try this. http://driver.wareseeker.com/free-sandisk-sansa-e260/
Jan 07, 2009 | SanDisk Sansa e260 MP3 Player
How do i update my firmware
It is pretty easy. If running Windows just download the Sansa Updater (see link below) and install it.
Then, use the Mac/Linux instructions (even if running windows!) to put the e260 into MSC mode- turn e260 on, switch e260 hold switch to on, press and hold the e260s LEFT button "<<" while you plug the USB cable into the e260.
For me (running Windows XP) the Sansa updater automatically detected the e260 then and updated the e260's firmware.
Links to the updater, and alternative complete instructions for Mac/Linux are here
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 07, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
  1. Turn on the e200 v2
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the e200 drive(s) to show up
  6. Follow instructions below and drag files to the e200 drive
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260 4GB Media Player manual
http://www.sandisk.com/sansa/#/support-0/
Jun 27, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
117 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
