Turn the oven off then wait for 2 minutes.then turn it on as normal after that hold the STOP/RESET button for 10 seconds.then check out by releasing the stop/reset button.if still the same problem again hold the same stop/reset button for 20 seconds.hold it bit tight pressed.then check out.if still the same problem then hold the stop/reset button again but this time press the stop/reset button randomly 10 to 15 times in 30 seconds non stop.
if still the problem then its the problem of door latch assembly got blocked internally to resolve it try this
Turn off the circuit breaker to the oven, remove bottom drawer, unplug the power cord, open the oven door, try pulling up the oven top; (there may be screws holding down the oven top). observe the locking mechanism, the plate the latch is attached to will sometimes catch on the arm that actuates the latch. Bend the plate down making sure the latch will not hit the top of the door opening. This should solve the problem. When the arm is caught on the edge of the plate the latch will hang in the closed or mid position. With the power off and the power cord unplugged you can also remove the back cover, (there may be a top and bottom cover), remove the top cover first. Remove the screw from the arm that's attached to the locking motor (you will is the arm extending from the front of the stove to the motor). Actuate the locking mechanism by pulling on the arm to see if it will move without any obstruction. As long as the locking motor and or oven control module is not defective.
if you require any part for the oven then you can get it from www.repairclinic.com or from www.partselect.com
This
will help. Thanks please keep updated.please do rate
the solution positively .thank you for using fixya.
There might be many reasons for the same. First, Unplug the same for few minutes and then Turn it back ON. Check, if the problem is solved.
If not, let me know along with few details :-
1. Do you see any error message ?
2. Is there any Self Clean option in this Model.If yes, have done that before all this happened?
3. Is this a permanent or intermittent issue?
4. What have you done to fix this?
5. How old this oven is?
6. Do you hear any humming noise?
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Unplug didn't work. No hum. No error signal except "LOC". Not intermittent. about two years old. You might know that from the sn#. Did you even know it was a Kenmore?
Kenmore oven model 790.49072400 sn# NF52117116. About three years old. Door is locked. It locked when I was setting/resetting the oven timer. The cancel (i.e., correct) button is next to a door lock button. I've cut the power for several minutes, no success.
If you don't have access to a manual for this oven, don't even bother to answer.
