Turn the ignition switch to the ON
(II) position.
Press the SEL/RESET button repeatedly until the engine oil life indicator is displayed.
Press the SEL/RESET button for about 10 seconds. The engine oil
life and the maintenance item code will blink.
Press the SEL/RESET button for more than 5 seconds. The maintenance item code(s) will disappear, and the engine oil life
will reset to ‘‘100.
If you have the required service done but do not reset the display, or reset the display without doing the service, the system will not show the proper maintenance intervals. This can lead to serious mechanical problems because you will no longer have an accurate record of when maintenance is needed.
Yes... go to that setting and old down the button for 20 seconds
