Question about Samsung ML-2510 Laser Printer
Makingcopies My printer will print only 1 copy even if it is set at 2 or 20. It started out printing about 20 pages and stopped. It got very hot and stopped printing completely. Now it will only print 1 page at a time. The troubleshooter states that it is offline but I have checked all the connections and they are tight. I have unplugged and replugged the printer from the power source and I have restarted the computer. Please help.
  • 84 Answers
Try to install it at another computer
if not relevant - this is the fuser i think
icq 475653626
Posted on Jan 04, 2008
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
My HP printer is printing multiple copies of the same document every time I print. The only way to stop it is to cancel the printing job.
it sounds like in your printer driver, the number of copies is set to more than 1 page.
go to printer drivers, and look under printing preferences, and look for what themultiple copies are set to.
Aug 30, 2010 | HP Office Equipment & Supplies
How can it set the printer up so that I have preferences i.e selection or number of copies or certain pages only?
This is done through the print software. Depending upon what program you are using, there may be more than one way to start a print job:
1) Click a print icon within the application - this will usually print with the default settings, (prints entire document, 1 copy)
2) Click the "File" menu, then select "Print..."
This brings up the print job with options for printing, for example number of copies, certain pages, order of printing etc.
If you found this advice helpful, please vote.
Jan 14, 2010 | HP Officejet J3680 Multifunction Printer...
Printer is making 2 copies instead of the requested one
when you go to print a page, click page setup, and change setting for copy's from 2 to 1...shia
May 22, 2009 | HP Photosmart C4280 All-in-One InkJet...
My printer,scanner and copier started behaving funny when i installed Vista Business. it prints a countless number of pages when a command is given.
Hi again,
I sugest that you download a new driver from here: - you have to join them in order to get the driver, but its free. NOTE, you problem might bee that you have installed a Vista32 driver on a Vista64 computer, please be sure to download and install the right one.
regards /Teis
Dec 29, 2008 | Office Equipment & Supplies
Prints java script instead of highlighted page
First, you probably should not stop the printer after it starts printing, it always creates problems. Second, you should clear your browser history and then you should select the range of pages to print on your print properties menu. If this does not work try reinstalling the print drivers.
Dec 13, 2008 | Brother MFC-210 All-In-1 Print/...
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
DELL A940-Good connection-no printing
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Nov 29, 2007 | Dell A940 All-In-One InkJet Printer
Samsung ML-2510 Laser Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
