Question about Magellan Maestro 4040 GPS Receiver
Magellan Maestro 3200
Do you know how to change the time on a Magellan Maestro 3200? The time zone is set correctly, but the time is 4 hours behind.
You may have the day light saving box checked iin your program.
Posted on Jan 14, 2008
How do I erase adresses that were put in the Magellan 3200
Posted on Dec 31, 2007
I need a free magellan maestro 3200 manual.
Hello therre:
Please follow this link to the manual and you can download it free it is in pdf format ok
Magellan Maestro 3200 Manuals, Support and Troubleshooting - GPS Free download of Magellan Maestro 3200 User Manual. Troubleshooting help from experts and users. Ask our large community for support.
www.retrevo.com/support/Magellan-3200-GPS-manual/.../2/ - Cached - Similar
Jan 16, 2010 | Magellan Maestro 3200 GPS
My magellan maestro 4040 is an hour ahead on the time. I have tried changing the time zone and region but no luck. Any ideas?
did you check off for daylight saving time?
its in the time zone settings..make sure the magellan is acquiring the satellites (it it displaying your location...if it is, its probably because the daylight savings time isnt checked
if thats not the problem, let me know and ill help you further.
bill
Dec 29, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 3200, GPS won't turn on anymore
my magellan maestro 3200 will not turn on
Nov 25, 2009 | Magellan Maestro 3200 GPS
How do you change the battery in Magellan Maestro 3200 GPS.
there are 4 screws, one at each corner under the round rubber plugs. remove them then remove the screws and gently pry the case apart using a tiny (jewelers type) flat screw driver and disconnect speaker from the board. you can now change the battery.
Aug 10, 2009 | Magellan Maestro 3200 GPS
Connecting my magellan maestro 3200 to my computer
normally, connecting a gps to a computer results in file explorer opening and displaying the file structure. A phone does the same thing. The gps may need to be set for that - Garmin is automatic.
a program that takes coord input needs to have the gps set to match what it wants as in nmea, garmin, etc.
Nov 13, 2017 | Magellan Maestro 3200 GPS
Magellan Maestro 3140 blanks out
There seems to be issues with magellan batterys, being subjected to the cold has also been proven to effect the battery life, magellan offers a 1 year service on all units. I hope this has answered your question.
Jan 14, 2009 | Magellan Maestro 3200 GPS
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Setting time for Magellan 3225
Its very simple to reset the time just follow the steps given bellow.
---> Click on OPTIONS.
---> Click on USER SETTINGS.
---> Click on TIME ZONE.
So when you click on the time zone you can rest time.......
Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3200 GPS - wrong time on unit
My Megellan Roadmate had the same problem the time was way off and the date read 8/06/2009 instead of 06/17/2009. I tried everything the previous posting mentioned to no avail. I called Magellan tech support and they talked me thru it. (1) Turn the unit on outside ( not in a building ) (2) Hold down on the power button for 20sec. then let go. (3) Turn the unit on and go to the map. (4) Touch the upper rt. corner were the bars are, the screen will change and say tracking X (#) of sattilites. wait untill the bars for the sattiligts all change to green now you can go back to the main menu and the time should be correct.
Jan 01, 2008 | GPS
Magellan Maestro 4040 GPS Receiver Logo
192 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
