Home | Bosch | 24 in. SHU66C02 / SHU66C06 Built-in Dis... | My sink got clogged and
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Problem for Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
By cimmie on Oct 23, 2009
My sink got clogged and now my bosch dishwasher SHU43C05UC wont fill with water. I read on line that it most likely is the float is stuck and to access the front kickplate needs to be removed. Is there a diagnostic test that I can do that will display on the LED to make sure that this is the problem. How involved is it to unstick the float. Can it be done without moving the dishwasher and just working from the kickplate area?
Comments:
Oct 23, 2009
- is the float switch in a bosch model shu43c easily accessible through the kick panel below. I would like to check it because my dishwasher is not filling up. There's faint electrically smell. I read that these dishwasher are notorious to work on because the parts are not easily accessible. My problem is that i need to access it without moving and through the kickplate, otherwise I will need to replace flooring.
Solution #1
posted on Oct 23, 2009
Somewhat Helpful)
taran_2005
Rank: Guru
Rating: 88%, 959 votes
There could be 2 reasons :-
1. Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
The procedure to check :-
1. http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-water-valve
2. http://www.partselect.com/repair.aspx?appliance=dishwasher&part=test-float-switch
The above one are generic procedure to check the same. One more thing, there could be only 2 reasons for the water not entering the Dishwasher. So, there is no need to run Diagnostic Test and all that stuff.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Comments:
Oct 23, 2009
- Thanks for your response!!
DID YOU CHECK THE INFORMATION HOW YOU NEED TO CHECK TEST FLOAT SWITCH??
Oct 23, 2009
- OOps...
It's my humble request to READ the solution, before asking one more Question. Yes, you need to remove the lower kickplate panel. There is no other way to check the same.
Hope i have answered the Question.
Thanks!!
Solution #2
Not Rated)
57 varieties
Rank: Guru  Bosch Expert
Rating: 88%, 510 votes
It is most likely that you need to do the following
Larger remnants of food that have not been trapped by the filters and have been left in the water can cause a blockage in the pump. The water is no longer pumped out of the dishwasher and it can be seen covering the filter.
Proceed as follows:
  1. Turn off the machine and turn off the mains power.
  2. Ladle out as much water as possible from the dishwasher.
  3. Remove the lower spray arm.
  4. Remove and thoughly clean the filters.
  5. Undo the screw in the cover (Torx T 20) next to the filter housing and remove the cover.
  6. Inspect the inside and remove any obstructions that you find.
  7. Re insert the cover and screw down.
  8. Re insert the filters and screw down.
  9. Check the waste outlet pipe for any obstruction and cleanas required.
  10. Make sure that the one way valve in the main sink waste system is clear of obstruction. This should be able to be unscrewed by hand and then checked and cleaned as required.
  11. Reasseble the waste outlet to the sink.
Popular Solutions for Bosch 24 in. SHU66C02 /
Questions and Unsolved Problems for Bosch 24 in. SHU66C02 /
Do you recommend Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher?
Answer
Answer
bosh dishwasher wont fill...also sink drains right into dihwasher ....
Answer
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from... (More)
Answer
Power problem with the bosch dishwasher model shu43c02uc
Answer
I can't find my manual so I need to review how to load the dishwasher the correct way. I feel I am... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C02 /...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
