Question about LG L1917S-BN 19" LCD Monitor
Pointer runing all over ny screen,but comes to a stop some times.i have a compaq evo n600c if thats any help duke o
0 characters
1 Points
My compaq n610c screen becomes very dim, with many small short lines blocks. Turn black after being on for a while. Please help. chee
I think the picture board on your monitor is malfunctioning that is why it brings those small lines on the screen, and since it even goes black after a while, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | Compaq EVO N600C (Refurbished) 14.1" LCD...
I need a vga driver for my evo n600c
Go to vendor website and select the appropriate driver may solve your problem.
Revert back for more assistance.
Jan 18, 2010 | Compaq EVO N600C (Refurbished) 14.1" LCD...
How do i replace the power jack in a compaq evo n600c?
This will require a full breakdown. Get the instruction manual from the HP site - it is a .pdf and gives you excellent step by step. Use a craft parts box from Walmart to keep the screws in order. The jack is a whopping $5 on eBay and it will take you 3 hrs or so to complete. JUST FOLLOW THE .pdf - NO cheating.
1 caveat: some of these laptops use a no longer available power jack - the ONLY way to get one is from an old mobo.
Oct 25, 2009 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Compaq n600c hang problem plz slove my problem
Please give more information Like --
After how much time it hangs?
what OS u r using?
in general answer --
open task manager (pressing CTRL,ALT, DEL keys) this will bring up Windows Task Manger, click on Application, highlight any task that is Not Responding and click on End Task.
Also, to make your CPU boot up faster, I would
click on Start
click on Run
type msconfig.exe (this will open System Configuration Utility box)
click on the Start Up Tab
(you will see several boxes checked under Startup Item). And look for programs that you don't want to launch every single time you log on. (such as Realpayer, yahooMessegner, realsched, etc).
Uncheck the boxes and this will require a reboot. Your computer will bootup a lot faster. These programs you can always open when you want. You can always tell if you have a lot of programs that startup when you turn on your cpu and in the righthand corner, where the time time is at, you see a lot of icons.
Also if you can always open up task manager again, click on Processes, find explorer.exe and kill that process, this closes everything on your screen. dont worry...
then in task manager
click on FIle
New Task Run
and type explorer.exe and click OK
and you will see all your icons pop back up on the screen.
Post reply....
Mar 22, 2009 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Disabled the video card so not the Compaq Evo N600c will not boot
While booting press F8 and pick the option "enable VGA Mode"
This shoud get you back to a place to re-enable the video. Also what wehre you trying to fix by disabling the video?
Dec 27, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
EVO N600c starts up fine but when when its time to sign in nothing on screen just blank
Both of you, what did you do before the restart? If you changed anything while in Winblows it seems likely it is a software related issue. If you didn't, then a hardware issue is possible, in which case I'd start by unplugging the non-essential peripherals and restart. If that doesn't work, also try a different power supply and disconnect the battery. Sometimes a bad peripheral can cause the boot up sequence to hang. And correct me if I'm wrong, but I believe a weak psu can undersupply power to the harddrive causing the operating system to fail to boot. But, you probably have tried these ideas so they may not be of much help. Oh well, good luck!
Jun 23, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Replacing ram in compaq evo n600c
The little screws are Torx head screws and sized by numbers. If you have access to a basic PC tool kit there is probably a couple of torx head screw drivers or torx head screw driver bits. Be sure to remove the battery and disconnect all other power sources. Ground yourself before handling memory modules.
Apr 07, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Compaq evo n600c
I do believe that there is no wireless switch on that model. To enable or disable the card is done through software. Check your Device Manager to ensure it is enabled and or correct drivers.
Mar 26, 2008 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
LG L1917S-BN 19" LCD Monitor Logo
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
