Home | Princeton Digital | VL1918 (Black) Monitor | Need free assistant to ...
Princeton Digital VL1918  Monitor
Problem for Princeton Digital VL1918 (Black) Monitor
Need free assistant to know if my Princenton
By dcechev on Oct 23, 2009
Need free assistant to know if my Princenton VL1918 monitor still is OK - Screen blinks every 5 secods, not able to work.
Solution #1
posted on Oct 24, 2009
Not Rated)
buddymc
Rank: Guru  Computer Hardware  Expert
Rating: 94%, 304 votes
Blinking power lights or flashing screens usually indicates a blown power supply. Heat buildup in the monitor case causes parts called capacitors to overheat and blow out. Check out our web site at: www.ccl-la.com/badcaps.htm We have pictures of what the blown capacitors look like. Open the back of your monitor and look for the blown caps. Replace all the ones that look like the ones in the pictures and you should be back up and running. The values you need to get are going to be marked on the sides of the ones you take out. Be sure to reinstall the new ones with the polarity stripe going the same direction as the old ones come out. You can order replacement parts from several places on the internet or we can supply them for you. You will need to use high temp caps that will be marked 105c, these are not available from Radio Shack. If you use ones that are not rated correctly then you will have more issues in a month or two. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Was this helpful?
Yes
No
Popular Solutions for Princeton Digital VL1918
Questions and Unsolved Problems for Princeton Digital VL1918
Do you recommend Princeton Digital VL1918 (Black) Monitor?
Answer
Answer
turn on power monetor flashes off on off ect also how do i install
Answer
I have a Princeton VL1918 Monitor with built in speakers. the volume is to low. how do I increase... (More)
Answer
It is a bit blurry and I want to know if there is a way to adjust the focus, or sharpness. None of... (More)
Answer
Princeton VL1918. Speakers stopped working. Check all connections. Other functionality is OK.
Answer
The Mac Mini that it's attached to is generating a proper video image, since I can mouse and click... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Princeton Digital VL1918 ...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
