I lost my Philips Cool Skin 7775X Electric Shaver charger.
For now i need to charge it another way. What votlage do I connect the shaver to - directly? And what side is positive?
Philips norelco 4222-039-10972 adapter charging cord for electric shaver norelco 7775x power cord replacement parts.
Hi, You can purchase a new charging cord from electricshaver.com for around $23.00 which is probably the best thing to do if you want to keep using the shaver.
Otherwise the specs for the shaver are as follows:
The part number for the replacement charging adpater cord is #3605160
Here's a link to the part you're looking for, should you decide to purchase a replacement instead of trying to make your own charger, which will be difficult unless you have the full array of electrical components and ability to fabricate it.
http://www.electricshaverstore.com/get_list_144.htm
You can also give them a call at 1-888-476-1785
Hope you find this Very Helpful and best regards!
thanks, I found the manual on the internet,
and I hooked a 12V SMPS PSU to the razor. I used tape to secure its wires to the 2 pins and viola!
The wrong way round is irrelevant, it is protected by diodes. The right way round, the red LED flickers, and after 3 minutes , the green charging LED lighted up.
It charged perfectly!
The next step is to purchase a charger.
In the mean time, I can shave.
The original charger is a small 12V transformer the can adapt to 120V-240V internally. I needed only to use one that is correct for our 230V supply.
