Lights were out, so I replaced them but none of them light up and the fan is off so are the panel lights. I cant find the internal fuses. Can this be done by me or do I need a repairman?
Is the fridge running cold as normal? If it is you will probably have to pull the back panel off the fridge to check all internal fuses and connections for internal lights and fan. That can be a shock or other hazard and usually requires a technician. If the entire fridge is out/not cooling (you said fan is off) then the follwing may apply: You may have already done this but please verify your outlet is OK with any other appliance or light or radio. Also you may plug your fridge in somewhere else just as a test. Many kitchens today do have sneaky GFI interruptor outlets for safety. If ANY other one outlet is tripped in the house it could kill power to other outlets too (these can have a little red-light on it) will need reset. It may not be the same outlet your fridge is plugged into. Some outlets can be off and others on.
Our ice maker is not making ice. From time to time we empty the ice holder to remove the collected...
(More)
Our ice maker is not making ice. From time to time we empty the ice holder to remove the collected frost. After returning the ice holder to the freezer, it made one tray of ice and since then it hasn't made another. We've turned both the ice maker off and the unit off a couple of times with no change.
temperature controls for refrig and freezer not functioning. thus cannot activate diagnostic, just...
(More)
temperature controls for refrig and freezer not functioning. thus cannot activate diagnostic, just turns off when attempting to go to mode? control board or control panel bad????
I have owned a sub-zero 690 for 8 years and have vaccumed the condenser many times but the flashing...
(More)
I have owned a sub-zero 690 for 8 years and have vaccumed the condenser many times but the flashing warning comes on a day later of when the grandchildren hold to door open to long. What do I do? Do I need to take all of the molding that hold it built-in off and vaccum behind it? It seems to have all of the workings above.
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the...
(More)
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the problem?
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to...
(More)
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to run all the time. The temps are OK. What elst should I look at
