Question about Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty washing machine 70 series
My washing machine fills up with hot water but not warm or cold water.
  • 1 more comment
  • NickyQ Mar 17, 2008
    My Whirlpool washing machine Model A7800YTWO does not fill with cold water...only hot water. No matter where I set the temperature switch, it only fills with hot water. Please advise.
  • Anonymous Mar 30, 2014
    Cold water fill only dribbles out. Warm and hot are very good.
    My washing machine will not fill with hot or warm water. I'm getting an error Fl
  • 550 Answers
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
Is your cold water valve turned all the way on?
Posted on Jan 03, 2008
    President:
  • 1,314 Answers
What is your selecter switch on water temp set to
Posted on Dec 30, 2007
3 Suggested Answers
  • 864 Answers
SOURCE: no cold water, only hot
Here are some things to check that are general for all washers.
Is the cold water turned on? Are the hoses connected to the correct faucets? Is the filter screen inside the hose where it connects to the faucet clogged? Do you hear a buzzing sound when the washer is trying to fill and is set to COLD only?
If all the above are OK then the temperature selector switch (or electronic control) may have to be replaced.
If there is no buzzing sound when the washer is trying to fill on Cold only, the solenoid valve (that the hoses connect to on the washer) may have to be replaced.
Posted on May 29, 2009
  • 2699 Answers
SOURCE: I have a Kenmore Heavy
shut the house water valve off,take off the cold water line on the back of the washer and stick it in the tub of the washer,have someone hold the hose and turn on the cold water valve,if water comes out then you need to change out the water valve on the washer,if no water comes out then you have a problem with the house water valve.there are screens in the valves see if you canpop out the screen and clean it out and put it back into the valve,you can try that but sediment could have went through the screen and damaged the valve,if so change it out.next time send the model number and i can give you part numbers,let me know what you find
Posted on Sep 04, 2010
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
I have a Kenmore Heavy Duty 70 series washer older model. It will not alow cold water to fill washer. Tried warm and hot water only fills the tank. Hot water will fill fine with no problem.
Sep 04, 2010 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
No cold water on any cycle. hot water fine.
The cold side of the water inlet solenoid is not working.
May 29, 2009 | Kenmore Washing Machines
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
The screens are filled with minerals which cause the washer to fill very slowly, need to know how to get at the screens so I can clean them. Kenmore Heavy Duty 70 Series washer.
HI thanks for your question.remove the hot& cold hoses. inside the valve you will see screens. scrape with a small screwdriver. replace hoses & try. if it works, great if not replace water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Washing Machines
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
990 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
