1998 Chevrolet C1500 Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1998 c1500 chev p.u. windshield wiper motor no go any speed
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Oct 23, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512698
Points
12435
Beyond the obvious answer of replacing the motor itself, check the fuse, and bad wiper switch, it could be just the auto-park switch on the wiper motor that is worn out.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 01, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
528
Points
There is a control card inside the wiper motor housing that may be defective,and it is much cheaper fix than replacing the entire motor!
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 07, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
2362
Points
10
The connection directly to the wiper motor is often loose. Wet the winshield, turn the wipers on, then try to move the connection. It will be obvious if that is the problem.
I have a 2007 chev uplander, when i start my van the wiper comes on,switch is in the off posistion HELP
Your best bet , have a qualified repair shop check it out . Check for DTC'S - diagnostic trouble codes in the BCM - body control module . Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• WPR1 relay
• WPR2 relay
• Windshield wiper motor
• Windshield washer pump
Wiper/Washer System Description The body control module (BCM) controls wiper motor low speed operation, washer pump and high speed operation. The windshield wiper/washer switch supplies a low or ground on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the WPR1 relay by suppling low signal to the relay coil. This allows battery voltage from the FRT WPR fuse to flow through the relay switched input then through the contacts and out the relay switched output to the WPR2 relay switched contacts. Since the WPR2 relay switched contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed. For HI speed operation, the BCM supplies the same low signal to the WPR1 relay control circuit and also supplies a low signal to the WPR2 relay control circuit. The WPR2 relays normally opened contacts are now in series with the current supplying WPR1 relay contacts. The WPR2 relay normally open contact at this point supply current to the wiper motors HI input.
could have a relay stuck closed or a BCM problem ,check for code's .
Where is the wiper relay switch on a 2004 cadillac cts
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor module
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Wiper/Washer System Operation
The windshield wiper motor module is part of the windshield wiper motor cover and controls wiper motor operation. The accessory voltage supply circuit to the windshield wiper motor assembly is used to operate the wiper motor in all modes. The windshield wiper motor is a 2 speed motor and is operated at low speed in all modes except HIGH. The accessory voltage supply circuit to the windshield wiper/washer switch is used to supply the windshield wiper switch signal circuits. The windshield wiper switch signal circuit voltage levels to the wiper motor module determine the wiper motor operating mode.
When the wiper/washer switch is in the LOW position voltage is supplied through a 24K ohm resistor within the switch to the windshield wiper switch signal 2 circuit, and accessory voltage is supplied to the windshield wiper switch signal 1 circuit. The reduced voltage from the wiper switch signal 2 circuit and accessory voltage from the wiper switch signal 1 circuit causes the wiper motor module to close the wiper motor accessory voltage supply circuit to the wiper motor low speed terminal.
1helpful
2005 crown vic. p71v 1st the fluid stopped and the wipers would'nt shut off, now 1 day later no fluid still and the wipers stop working completely, please help me
Principles of Operation
The windshield wiper motor receive inputs from the following:
  • multifunction switch
  • lighting control module (LCM)
  • ignition switch
  • battery junction box (BJB)
  • central junction box (CJB)
The following components are integrated into the windshield wiper motor:
  • windshield wiper motor module
  • high/low speed relay
  • run/park sensor (Hall effect)
  • washer pump relay
High Speed Windshield Wipers
High speed is activated when the multifunction switch supplies ground to the windshield wiper motor module inputs. The windshield wiper motor module then supplies ground to the run/park sensor and high/low relay coil, activating the relay with voltage supplied from the ignition switch (RUN/ACC) through the central junction box (CJB). When the windshield wiper motor module receives voltage from the run/park sensor, it removes ground from the run/park sensor, deactivating it. The windshield wiper motor continues to operate from voltage connected through the run/park sensor until the Hall effect senses the magnet in the motor. When the Hall effect senses the magnet in motor the windshield wiper motor returns to the park position, the internal run/park sensor grounds the windshield wiper motor module input and the windshield wiper motor module removes ground from the windshield wiper high/low relay coil, deactivating the high/low relay and windshield wiper motor. The windshield wiper motor module continues to cycle the windshield wipers until the inputs from the multifunction switch are changed from the high speed position.
Low Speed Windshield Wipers
Low speed is activated when the multifunction switch supplies a specific ground to the speed inputs of the windshield wiper motor module. The windshield wiper motor module then supplies ground to only the windshield wiper run/park relay coil, activating it. When the windshield wiper run/park relay is activated, the deactivated windshield high/low relay connects voltage to the windshield wiper motor low input activating the wiper motor. The windshield wiper motor module continues to operate the windshield wiper motor in the same manner as in high speed, but in low speed with the wiper motor connected to the low speed input.
Intermittent Speed Windshield Wipers
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper run/park relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated, supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect sensors senses the wiper motors magnet, which turns off the run/park sensor output to the windshield wiper run/park software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle.
Washer System
The windshield washer is activated by the internal wiper motor module when it receives a ground from the multifunction switch between the washer input. Dependent on the correct ground, the internal wiper motor modules activates the windshield washer relay (internal) by grounding the respective relay coil. When the relay is activated, it connects voltage to the washer pump while the washer level switch provides ground to the washer pump.
Default Mode
The windshield wiper motor defaults to this mode when the run/park sensor does not sense the hall effect magnet inside wiper motor. This can be caused by obstruction of the windshield wipers or a binding linkage. The windshield wiper motor will continue to operate in a high/low speed condition for a period of 60 seconds.
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The wipers are inoperative
  • Multifunction switch
  • Circuitry
  • Ignition switch
  • Go To Pinpoint Test A .
Do you know how to test automotive electrical circuits using a factory diagnostic test procedure flow chart ?
PINPOINT TEST A: THE WIPERS ARE INOPERATIVE Test Step Result / Action to Take A1 CHECK CIRCUITS 65 (DG) AND 2025 (RD/YE) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Windshield Wiper Motor C125.
  • Key in ON position.
  • Measure the voltage between windshield wiper C125 pin 5, circuit 2025 (RD/YE), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 65 (DG), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to A2 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A2 CHECK CIRCUITS 57 (BK) AND 676 (PK/OG) FOR OPENS
  • Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 676 (PK/OG), harness side and ground.
  • Are the resistances less than 5 ohms?
Yes
GO to A3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A3 CHECK THE MULTIFUNCTION SWITCH
  • Disconnect: Multifunction Switch C202b.
  • Carry out the multifunction switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Does the multifunction switch pass the component test?
Yes
GO to A4 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 . A4 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between C202b pin 5, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to A5 .
No
REPAIR the circuit. TEST the system for normal operation. A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
  • Using the following table, measure the resistance between the multifunction switch C202b harness side and the windshield wiper motor C125 harness side:
    Multifunction Switch C202b Windshield Wiper Motor C125 pin 6, circuit 56 (DB/OG) pin 10, circuit 56 (DB/OG) pin 3, circuit 58 (WH) pin 11, circuit 58 (WH) pin 1, circuit 61 (YE/RD) pin 1, circuit 61 (YE/RD) pin 4, circuit 63 (RD) pin 9, circuit 63 (RD)
Yes
GO to A6 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
  • Disconnect all wiper motor connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all wiper motor connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
GO to A7 .
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. TEST the system for normal operation. A7 CHECK THE WINDSHIELD WIPER MOTOR
  • Carry out the windshield wiper motor component test as outlined in this section.
  • Does the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. The concern may have been caused by binding or incorrect pivot arm adjustment. REFER to Windshield Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
How do I find out if the wipers on my 2006 H3 Hummeris on a relay?
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIP/WASH 10A fuse
• WIPER 25A fuse
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper micro relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay switched output to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit, and energizes the wiper micro relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool, by commanding Wiper Relay Cmd. ON and OFF. Refer to Scan Tool Output Controls .
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper micro relay and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper micro relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During high speed wiper motor operation the wiper switch signal circuit is at the low speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
This info is out of hummer factory service manual !
My front windshield wipers will only work on high. Any suggestions?
Search Results
    My windshield wipers only work on high speed...? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...
    Nov 11, 2006 - My windshield wipers only work on high speed. ... If it's the compound switch on the lever on the steering wheel, it can be a bit complicated to ...
    Windshield wipers - CarGurus
    www.cargurus.com > Questions > Mercury > Grand Marquis
    CarGurusMay 19, 2015 - Windshield wipers - My wipers stopped last week and the next day they ... slow or intermitt and only work on high speed and the washer wiper doesn;twork ... The LCM does not effect the operation of the motor or switch it just ...
    Windshield Wipers only working at highest setting - Ford Flex Forum
    www.fordflex.net > ... > General Ford Flex Discussions
    Feb 16, 2011 - Windshield Wipers only working at highest setting ... rear wiper worksjust fine, just the front wipers only work at highest setting. ... the wipers sometimes grinds out the gears thus only working at high sppeds. If it is the motor or Transmission for the wipers, can I fix this myself and how much would it cost me.
    Common GM Wiper Problem - YouTube
    ? 3:23
    https://www.youtube.com/watch?v=kc6e2Tmar68
    Oct 25, 2010 - Uploaded by roadragecustoms
    The windshield wipers only worked occasionally. ... My 1998 dodge ram wipers only work on high will this help me? thanks.... Express van. you have to take out the motor and the transmission from under the front of the van..
5helpful
Windshield wipers will not shut off
Hello, my name is Ben. This is a very common problem for GM. You have a wiper motor control module and it is most likely defective. The module is bolted directly onto the wiper motor which is mounted to the firewall under that long plastic cowl just in front of the bottom edge of your windshield.
1helpful
Windshield wipers dont work all the time
very common chev problem. tap on the circut boart part of the motor and see if they start. replace the circut board only, you do not need the whole wiper motor
1helpful
Need to get a programmer dont know where its at
  • Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
  • Damaged turn signal and windshield wiper switch .
  • Damaged windshield wiper motor .
  • Damaged windshield wiper control module.
Pin Number Circuit Circuit Function 1 57 (BK) Wiper Motor Ground (Park) 2 28 (BK/PK) Wiper Module to Wiper Motor (Park Switch) 3 65 (DG) Wiper Motor Power (Park Feed) 4 61 (Y/R) Wiper Motor Common (RUN) 5 56 (DB/O) Wiper Motor LO 6 58 (W) Wiper Motor HI
Windshield Wiper System The windshield wiper system consists of :
  • Windshield wiper motor (17508) (F-type).
  • Washer system.
  • Windshield wiper control module.
  • Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
  • Located at the instrument panel fuse panel.
The windshield wiper motor is:
  • Attached to the cowl top extension (021A36) .
  • Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
  • Rotary wiper switch.
  • Push type washer actuator.
OFF/Low/High Speed
  • Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
  • The windshield wiper motor has a brush rigging that permits selection of low or high speed.
  • When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
  • When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
  • In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
  • When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
  • When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
  • The wipers make single wipes separated by pauses.
  • The rotary switch is on the end of turn signal and windshield wiper switch .
  • The length of the pause can be set from approximately 1 to 17 seconds.
  • Length of pause decreases as the rotary switch is rotated away from off.
  • Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
  • It is normal to hear a slight click at the beginning of each on/pause cycle. NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
Wipers not working
First thing you could try is replacing the circuit board on your wiper motor. It's behind the black retangular box on your wiper motor. Not hard to change. A few screws and a plug in. Or- change the whole wiper motor. ( about $80 more than the board) Bolts can all be accessed by removing the cover at the bottom of your windshield. Pretty straight forward.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
