Question about Flat Panel Televisions
Poor Picture Quality
We bought an LG 42" LCD tv about a week ago (model no 42LC55) but the picture is always slightly blurred. We can't seem to get a crystal clear picture, not even when watching a DVD. Does anyone know how to fix the picture quality? Thanks
4 Suggested Answers
  • 173 Answers
SOURCE: Poor Picture Quality on Philips 42PFL7962D
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Posted on Dec 05, 2007
  • 5 Answers
SOURCE: samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Posted on Dec 31, 2008
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Posted on Apr 30, 2009
  • 8909 Answers
SOURCE: Picture quality is too bad in NEW sansui 32" LCD
As it is new, take it back for replacement. If you bought in online, have it replaced as it may have been damaged in transit.
Don't bother to try and repair it, it is not right.
Hope that helps.
Posted on Nov 27, 2010
0 characters
1 Points
I have successfully connected my PC to the TV. But it only works in 1024x768 mode. Any other mode results in "invalid format". In the TV on menu selection under the picture sub menu the...
User manual:
See page 38~40 for what the TV can do when it is used for PC display.
From user manual:
37/42/47/52LG50, 32/37/42/47/52LG60,
32/42/47/52LG70, 42/47LGX, 47LG90,
50/60PG60, 50/60PG70: To get the the best
picture quality, adjust the PC graphics card to
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 15, 2011 | LG 42LG30 42 in. LCD HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
I want the best picture from my 50" LG plasma tv, and I just replaced my 47" LCD LG tv with this plasma and I am not impressed at all compared to my LCD. I guess my question is what a are the best picture...
Hi, I recently bought a 47" LCD LG the latest model and I read that you had purchased it previously and I wanted to know how you found the quality of picture on the LCD? At the moment ours is a bit blurry. I hope it was worth buying. Do you think we just need to tune the picture quality?
Jan 07, 2010 | LG 50PX5D 50 in. Plasma HDTV
The red stand by light is on but the screen is
This is a common problem with LG 42 and many were recalled to change the offending board and part of this p-oor quality TV
March 9th, 2009
Pros: The picture is good, great size for our well lit 7m x 7m room.
Cons: Sound delay - we assume that is to do with being digital, the sound lags behind other analog TV's in the house.
Overall: LG service is pretty ordinary (not just for TV). There was a product recall on this TV, but the service department was unaware it covered this model - I had to print out the details from the LG website when the serviceman came. We've now had the TV for over 2 years and a red tinge became apparent at top and bottom of screen, we placed a warranty call and the local service agent came and took the TV away two weeks ago. They are still awaiting parts from LG to repair the problem.
Please rate my help++++Thanks for using FIXYA
Nov 27, 2009 | LG 42LP1D 42 in. LCD HDTV
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Sound slightly out of sync with picture on LG 42" tv
I would advise you to contact your LG dealer as there was a software issue which related to this problem & would need to be carried out by an engineer.
Jul 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Lg 37 inch lcd tv model 37lg3000
You may have got a bad unit but more likly it's your cable you are using I have found with the newer HD units the siganal has to be real clean coming in or you do get a distorted picture. Try changing out you cable lead for a good quality cable,
Nov 16, 2008 | LG 37LC7D 37 in. LCD HDTV
Flat Panel Televisions Logo
168 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
