Question about Samsung Techsan LM1770A 17" Monitor
How do I fix my monitor when Windows open too large?
I have a Techsan LM1770A. How do I change the size of a window that opens too large to see the full screen? I have to scroll left and right just to read the news. I know very little about hardware. Computer is used. I am apparently using default monitor settings from my Dell piece of crap. Are there drivers for monitors (which I don't have)? If so, where can I get them?
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
Why do windows change size/position whenever I power off monitor?
HAVE YOU READ THE MANUAL AS YOU DESCRIBE IT CAN BE AUTO ADJUSTING.
NEVER TURN OF THE MONITOR BEFORE WINDOWS.
Jun 26, 2013 | Computers & Internet
Font sizing
Where do you want to change the font size on the overall computer or in a word document?
In a word document you will see a number at the top of the window that represents the font size that you can change. If you have problems within word there is a Help option where you can simply type: Font Size and it will bring up instructions to change.
To change font size on everything in the computer:
Find an open space on the windows desktop and Right Click then select Properties. When the Display Properties window opens click the Appearance Tab then look down towards the bottom left you will see where you can change the font size from Normal to Large or Extra Large. Change the size then Click Apply then click OK.
You can also get the Display Properties by clicking Start/Control Panel and look for Display or Appearance and Personalization. Once the display opens click the Appearance tab to change the font size.
Apr 27, 2012 | HP Computers & Internet
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Mar 03, 2011 | Computers & Internet
Screen to big !!! icons extra big and internet screen incompletes
Hi Jessica, on your "Desktop screen," [right / alt click] to open the shortcut menu, next select one of the choices for the "icon size, ie: Medium or Large. In the same "Desktop" shortcut menu click on "Personalize," in the next window, left "Tasks" area, select and open the "Adjust font size (DPI), change the size in the [DPI Scaling] window, select the "Default scale size (96 DPI)," or you can use the {Custom DPI...} below to change the size, to your preferences. If the suggestions helped, show your appreciation for the services by giving a "Helpful Rating" thank you for using "Fix' Ya."
Aug 07, 2010 | Computers & Internet
My gadets slide bar has gone how do i get it back
To open Sidebar
Open Windows Sidebar by clicking the Start button , clicking All Programs, clicking Accessories, and then clicking Windows Sidebar.
To keep Sidebar visible at all times, you must set it so that other windows won't cover it. The Sidebar width is a fixed size.
To keep windows from covering Sidebar
Because of the space Sidebar requires, this option works best if you're using a large or wide-screen monitor or multiple monitors.
1.
Open Windows Sidebar properties by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Windows Sidebar Properties.
2.
Select the Sidebar is always on top of other windows check box.
3.
Click OK.
Sep 18, 2009 | HP G70-250us Notebook
Need a power cord I think my wife tossed it???
You can buy a regular power cord at the store such as wal-mart, staples, bestbuys. Most monitors have a standard power cable, similar to that of the computers.
Apr 25, 2009 | Samsung Techsan LM1770A 17" Monitor
LM1770A POWER ADAPTER 12V
Ok well the Power adapter is not really that special.. what you need is a Centre Pin POSITIVE 12volt at say 4 amp power supply unit. I would get it from Ebay.. perhaps even being able to get an exact one from Ebay.. Othewise try the Samsung site and purchace direct. Look here for an idea. http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=power+supply+for+LCD&_nd1=See-All-Categories
Jul 31, 2007 | Samsung Techsan LM1770A 17" Monitor
Samsung LM1770A 17
Most probably the Power Supply, generally is in these things... perhaps the Electrolytic Capacitors have Dried out and gone bad and need to be replaced, often all I do is replace every large Electro on the Power Board, (Often with much higer Temperature and spec Caps) and that "Fixes" it..
Jul 13, 2007 | Samsung Techsan LM1770A 17" Monitor
Samsung Techsan LM1770A 17" Monitor Logo
50 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
