Home | Rancilio | Silvia Espresso Machine | Rancilio Silvia lea...
Rancilio Silvia Espresso Machine
Problem for Rancilio Silvia Espresso Machine
Rancilio Silvia leaks around group head. Gasket seems fine.
By scottdanzig on Oct 23, 2009
I have a Rancilio Silvia that used to be leak free and, given the right grind, would pull a good double shot of espresso in 25 seconds or so. It's now leaking around the edges, and I made sure the grind was the same, and the filter was clean. Also cleaned the gasket that forms the seal with the filter, which doesn't seem to be hard nor cracked at all. And I recently decalcified the machine. I remember this problem happened before when I was tightening the portafilter too much, but I haven't been doing that and now it's leaking water more and more. There's no significant water collecting above the coffee grinds, so I don't think it's ground too fine. What should I check next, or what sort of repair would I need?
Solution #1
posted on Oct 23, 2009
Not Rated)
bansheracer
Rank: Guru  Kitchen Appliances  Expert
Rating: 92%, 172 votes
HI
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don't form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Was this helpful?
Yes
No
Popular Solutions for Rancilio Silvia Espresso
Questions and Unsolved Problems for Rancilio Silvia Espresso
Do you recommend Rancilio Silvia Espresso Machine?
Answer
Answer
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and... (More)
Answer
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been... (More)
Answer
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,... (More)
Answer
bad check valve in rancillio silvia? pressure loss thru group head while steaming
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rancilio Silvia Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
