Legend lc1916l remote control codes
I need the remote control codes for a legend brand tv/monitor model lc1916l.need to do a channel search for hd antennae,none of the universals seem to have the codes and doing code search only got me on/off and basic channel and sound controp but no set up
  • TinRudder Jan 06, 2008
    I have the same problem. Have tried two replacement remotes and none of the codes will work. TV has a great picture but a remote would be nice ...
  • DAN1229 Dec 09, 2008
    I HAVE THE SAME PROBLEM NEED THE CODE TO LC1916L A NEW RMOTE COST 69 DOLLARS SO PLEASE GET A CODE THANKS DAN LET ME KNOW
SOURCE: ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Posted on Dec 07, 2007
SOURCE: Legend LCD LC1916L TV Picture
try contacting this e-mail at legend i have the same prolem
digitalsupport@legenddigital.com <digitalsupport@legenddigital.com>
Posted on Mar 12, 2008
SOURCE: moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Posted on Nov 15, 2008
SOURCE: code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Posted on Dec 23, 2008
  • 5 Answers
If you unplug the unit from wall plug for ten minutes, it should reset the picture. I would unplug the a/v cables also in case of a ground loop
Posted on Sep 26, 2009
I have a teac LCD TV/DVD combo model LCDV1955 HD made in December 2008 and I cannot get a audiosonic universal remote control model JLR-6002 to work
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 02, 2015 | Universal Remote Control Televison & Video
Trying to program tek remote with Cox Cisco Model E320VL and TV Vizio model DMS2344.
Nov 29, 2015 | Universal Remote Control Tek Partner...
Sony rmt-b118a hd code
If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.Check this site too. http://electrohelponline.blogspot.com/
Apr 27, 2013 | RCA RCU410 Universal 4 in 1 Remote...
I need the codes for PHILIPS Sru 2103/27 universal remote control for Philips tv
Hello
There is no manufacturer code given in its manual. But you can find out the code of your device to be controlled with this remote control.
Code search by Brand
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Mar 10, 2011 | Philips Televison & Video
I have an emerson ewf2006 tv i have no remote but i do have a philips universal remote model cl034. i cant seem to find a code to make it work. does that remote even work for that tv? or do i need to...
Hello
Your Philips CL 034 model remote control should work with almost all models of Emerson TV. Codes to check with are
0002 0502 0006 0115
0506 0706 0520 0906 0316
0505 0614 0324 0924 0626
0826 0027 0327 0128 0228
0632 0134 0247 0605 0705 0805
0703 0903 0004 0519 0106 0104
0304 0604 0804 0005 0105 0305
Be patient and check with these codes one by one, till you find the code for your Emerson model.
NB: Switch OFF and switch ON your TV set, with its front panel power control switch, before trying an other code.
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Brand within the Code Library for a
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
(0-9) corresponding to desired
Manufacturer (see table below).
library search same as Device Library
Code Search Method.
POWER or PLAY (VCR only))
the code.
OK.
Feb 28, 2011 | Emerson EWF2006 TV
Hi Toshiba Team, I have a Toshiba MD20FL1 and need a new remote control. Tried 2 different remotes and none of them worked so far. I know that this Toshiba model is a little old for a TV but I don't...
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your Toshiba set is listed in its codes and are given here.
......... 0517 0419 0512 0613
........................... 0719 0112 0506 0111
........................... 0618 0627 0437 0041
................. 0094 0802 0111 0313 0715
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
Note, when all codes under a Brand
have been searched the red indicator
Dec 08, 2010 | Toshiba MD20FL1 20 in. TV/DVD Combo
I NEED A CODE FOR THE REMOTE AND TO KNOW WHAT KIND OF REMOTE WILL WORK FOR MY TV. PLEASE
Hello
Your Konka TV can be programmed with Philips Universal Remote control MODEL [CL 034]
The codes are
0906 0702 0203 0306
0208 0911 0842 0942 0504
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK
Nov 22, 2010 | Konka A2781U 27" TV
Need code for a legend tv
Hey there,
This brand uses the same code as sylvania/emerson. Try using the emerson codes, and that should give you the basic functions with remote. Here are some of the emerson codes. Just drop first 0 if your remote only takes three #s. Try each until one works. Good Luck!
0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
Nov 30, 2008 | Radio Shack 15-2142 Remote Control
Feb 29, 2008 | Televison & Video
Universal remote codes
google search the brand and model of the remote shouldny be hard to find
Nov 23, 2007 | RCA RCR660 Remote Control
Televison & Video Logo
1,057 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
