Question about Durabrand DVD-1002 DVD Player
DVD doesn't spin
The spinning mechanism on this DVD player stopped working last night. But I don't see any issues save for the piece that holds the DVD's seems different. I can't really describe how, except for the small circular piece on the very top of it seems scratchy, but I didn't pay enough attention to it before so I don't know weather or not it's actually any different than it was before.
  • tommyt1234 May 01, 2008
    Same problem. Checked +/- 12 Vdc reads 8.5Vdc I don't think thats enought for the 12 volt motor the +/- 5vdc is correct. But a drawing on the power supply would be nice.
  • Anonymous Aug 19, 2008
    DVD motor not spinning enough to get the disc to be recognized. Cleaned parts that I could. It is dead. I guess made in China should be a warning now as I have found a similar issue with a CD player that had its motor go out as well.
  • 537 Answers
The spindle motor could be burned out. If so, it's not worth repairing unless you could find on ebay an equivalent unit and change the part yourself.
Posted on Jan 01, 2008
The disc starts to spin then stops?
If the player is not able to spin the disk up to full speed in X amount of time the default is to shut down.
So most likely you need a new player.
But first try unplugging the power to the player for one minute to reset it then plug it back in. & give it a try.
next it might be getting to hot maybe dust buildup at vents or placed on top or too close to something that makes heat.
Again unplug & let it get to room temp maybe over night then try it again.
Lastly you could try a lens cleaning disk. Maybe the lens can't read the disk & this is causing it to stop trying & stop spinning. This is a long shot as if it's a read fault it should display that message.
Sep 20, 2015 | Televison & Video
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I load the CD put I don't hear it spinning at all
No it isn't, because your switch isn't tripping when you close the DVD. Try holding the lid down with your hand and listen for spin. If your DVD starts spinning you will need to locate the plastic pin protruding from your lid and extend it with superglue and a piece of cardboard. This will make up for the warp in your lid, and allow the switch to close.
Mar 09, 2010 | Mintek MDP-1810 Portable DVD Player
Dvd player not reading new DVD
probably needs a new belt they do wear out and loosen up over time
Feb 16, 2010 | Philips DVP1013/37 DVD Player
Durabrand DVD-1002 DVD Player Logo
55 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
