Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Refridgerator door handle
I have a loose screw on the door handle of a whirlpool refridgerator. how can i get at the screw to tighten it?
  • 4 more comments
  • Tnettling Jul 27, 2008
    Whirlpool Gold Model GS6SHAXMTOO. Refrigerator side door handle is coming loose. How do I tighten? Tom
  • Anonymous Aug 26, 2008
    how do I tighten handle screws
  • abbysilva Jan 02, 2009
    My refrigerator handle has come off on the top of the door. please help.
  • Anonymous Apr 03, 2009
    same kind of refrigerator- fridge side handle is coming off at the top.
  • Tnettling May 11, 2010
    Model #GS6SHAXMTOO. Nothing behind gasket. Is the cap you are addressing on top of the door? Tom
  • Anonymous Mar 13, 2014
    how to tighten the handle on the refrigerator door of a whirlpool model#GX2SHBXVQ03
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Posted on Mar 18, 2009
Some Whirlpool models have a handle that is in three main pieces; the top-mounted holder, the bottom-mounted holder and a handle that is supported in between them. For this type, remove the plastic end cap for the holder that is loose by taking a very small flat screwdriver and tapping the cover off of the end (the top one you tap straight up and the bottom you tap straight down).
The there is a cover in the handel holder that snaps in place into a channel in the holder. With the end cap removed, you can carefully pry it out - be very careful to pry out from a shallow angle -10 to 20 degrees. If you stick a small screwdriver underneath and pry out at, say, 45 degrees, you may bend this cover (the very end does bend a little, but don't worry about that). Just make sure you are sticking the screwdriver in very far and then gently pry off the cover.
With the cover off, you will see the screws that hold the handle to the door. These are frequently Torx screws (they look like little stars) that are T-20 in size. Tighten these down, but not too tight or you may strip the threads.
Snap the cover back into the channel in the holder and slide the plastic end cover back into the end and you are done!
Posted on Oct 08, 2009
Some there is a plastic sleve or cap you push up to get to it some you open the door and pull back on the gasket to get to hard to know without mod num
Posted on Dec 30, 2007
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
The screws holding the handle on the oven door have come loose. How do you get at the screws to tighten them? It is a Whirlpool range designer model.
Without a model #, I would say you need to take the oven door off and disassemble it to get at the screws holding the door handle. Some models have screws going right through the door to hold the handle on. Best of to call a certified repair company such as Sears.
Mar 20, 2010 | Kitchen Ranges
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Oct 18, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
698 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
