Sony BRAVIA  KDL-40V2500 40 in. HDTV LCD Television
Problem for Sony BRAVIA KDL-40V2500 40 in. HDTV LCD Television
Buzzing/fizzing noise from back of sony flat screen tv
By neil_ayscoug on Oct 23, 2009
All the time my sony 40w5500 bravia is on I can hear a buzzing/fizzing type of noise from the back top right hand corner. Not very loud. This maybe quite normal? Can anyone put my mind at rest? The TV works perfectly.
Clarification Request
Posted by techwurx on Oct 23, 2009
Maybe some clarification could lead to more peace of mind. Just as an FYI: Many power supplies inside such units today will generate a very low buzz as it converts wall power to DC inside and generates a "buzz" in some cases to do so. However if the noise is objectionable when listening to TV sound it may be a filtering defect. Interference: It is possible some other device nearby or plugged into the same outlet is simply creating interference. You can try ensuring no other electronics are close-by, using a different outlet with nothing else plugged in, or a good power strip. Also if the unit has a three-prong plug be sure that all three pins are connected to a good grounded outlet to get best (and safest) results. If that is no help: Do you know anyone else with same TV model you can check with to hear what theirs does? Or any same model units in a store nearby where you may be able to stop by and check?
Best Solution
posted on Oct 23, 2009
Very Helpful)
welcomejee
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 89%, 3149 votes
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you very much for the very prompt reply. This seems a very likely cause. My TV is only a week old so I will contact the supplier. Thanks again. " - neil_ayscoug
Popular Solutions for Sony BRAVIA KDL-40V2500 40
Questions and Unsolved Problems for Sony BRAVIA KDL-40V2500 40
Do you recommend Sony BRAVIA KDL-40V2500 40 in. HDTV LCD Television?
Answer
Answer
I have a Sony Bravia KDL-40v2500 lcd that i bought as a non working unit. It was flashin 3 blinks... (More)
Answer
Stand by light blinking 3 times in a row-then pause, then blinks. Will not turn on
Answer
I am getting a blue line, vertical, down the right hand side of the screen. It will fade in and go... (More)
Answer
when I switch from a 720 hd channel to a 1080 hd channel the screen splits and freezes, or stretches... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
