This usually indicates a power supply that is about to fail. Heat buildup in the
monitor case causes parts called capacitors to overheat and blow out.
Check out our web site at: www.ccl-la.com/badcaps.htm
We have pictures of what the blown capacitors look like. Open the back
of your monitor and look for the blown caps. Replace all the ones that
look like the ones in the pictures and you should be back up and
running. We are working on a step by step repair guide that should be posted on our site by the end of the week. The values you need to get are going to be marked on the sides
of the ones you take out. Be sure to reinstall the new ones with the
polarity stripe going the same direction as the old ones come out. You
can order replacement parts from several places on the internet or we
can supply them for you. You will need to use high temp caps that will
be marked 105c, these are not available from Radio Shack. If you use
ones that are not rated correctly then you will have more issues in a
month or two. If you don't want to do the repair yourself we do offer a
repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
When I turn on my pc and it first comes on it takes awhile for the color to go from real dull to its...
(More)
When I turn on my pc and it first comes on it takes awhile for the color to go from real dull to its normal crisp color. I have replaced the cable and replaced the video card with a top of the line Nvidia one. Any suggestions?
My samsung 245 monitor needs cleaning and accumulates black spots all over. How would I clean that?...
(More)
My samsung 245 monitor needs cleaning and accumulates black spots all over. How would I clean that? I tried rubbing them off with a soft cloth, but only spread them
nvidia doesnt recogninse properly, so i cannot set 1600x1200 res. but will let me set it as a wide...
(More)
nvidia doesnt recogninse properly, so i cannot set 1600x1200 res. but will let me set it as a wide monitor ie. 16??x1050 or something like that. I've tried to manually change settings, by defining a 1600x1200 but that doesnt work.
The lower third of the screen is washed out and has a ghost image of the desktop when I use any...
(More)
The lower third of the screen is washed out and has a ghost image of the desktop when I use any application.
