Question about Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
No color or sound on DVD Player when hooked up with the ShowStopper
I recently had new flooring installed and all my connections were removed. Now I cannot hook up the connections correctly to watch DVD'S - there is no color or sound on the DVD player.
I have a Westinghouse LCD TV with the Panasonic Showstopper PV-HS2000 and a Coby DVD-224 player. I've tried S Video and the Component video cables the with standard video cables.
The CATV cable from the wall is plugged into the Showstopper. Then the Showstopper has the Red/White/Yellow cables to the TV - Video, R & L then another set of video R & L to the DVD player. The Component cables from the TV to the DVD player. When that didn't work at all I put in the S Video from TV to DVD and the DVD plays but with no color or sound.
PLease help - I'm a novice and don't understand a lot of this.
Thanks,
Ann
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Posted on Oct 14, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
How do I connect the DVD player to my tv? My last DVD player had a place on the back to be able to hook in the cable along with the color wires. This DVD player does not have a place to hook in the...
What colour wires does the new dvd player have? The colours correspond with the socket that you plug them into. If your new dvd player only has yellow red and white cables then that is all you need. if they are red blue and green then you will also need to plug the appropriate audio cable into the dvd player. If you need more help please tell me the model of dvd player and the model of tv
Dec 25, 2010 | Televison & Video
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
No color and no audio
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
Jan 08, 2009 | GoVideo Go Video DVD/VCR Combo
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
No sound on my toshiba television
just be basic....dvd is ouput goto tv input...watch the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Apr 26, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder Logo
135 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
