The replacement trigger valve assembly will not go in my N60Fn Stanley Finish Nail Gun. What do I...
(More)
The replacement trigger valve assembly will not go in my N60Fn Stanley Finish Nail Gun. What do I need to do?
paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so...
(More)
paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so when I fire it no nail is picked up by the firing pin. batteries are good(new), cylinder is new, any ideas? When I take my little combination square and push the piston back up approx 1/2 '' then it works good for a couple shots,then back to the same old thing, firing but no nail.
the nailers jams every 15-20 nails and have to open the assembly to clear out the jam and...
(More)
the nailers jams every 15-20 nails and have to open the assembly to clear out the jam and reset....bought this from Home Depot and have had it exchanged 3 times....frustrating...using it on 1/4" mouldings...please advise on this issue....thank you
I just rebuilt my Senco SN4 nail gun because it had a constant air leak coming out of the discharge...
(More)
I just rebuilt my Senco SN4 nail gun because it had a constant air leak coming out of the discharge vent on the top of the gun. I replaced all of the o-rings that came with the kit except there is a split gland seal in the mechanism above the piston. Is this seal suppose to be split, and should one have come with the kit? I'm not sure if this is the problem, but the leak has not changed at all.
