Question about Nintendo DS Console
Clean how do I keep the back and the screens clean
  • 51 Answers
The DS Lite is a fingerprint magnet, unfortunately. Clean the screens with a lint-free cloth. Dampen it slightly if the smudges refuse to come off. The outside of the case can be cleaned in the same way, but since it's a glossy finish it always tends to show prints.
There are thin plastic films that you can place over your screens to help ward off scratches and smudges as well. Your mileage may vary.
Posted on Apr 13, 2009
    New Friend:
  • 127 Answers
Use a show buffer cloth, or soft felt.
I know it sounds weird, but it helps.
Posted on Dec 31, 2007
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
I have an older Pioneer rear projection TV that has never been cleaned, model SD-P50A5-K. Can you give me the basic cleaning instructions and the do nots for this TV.
Unplug the TV for safety - even unplugged, there is enough energy stored in the electronics to be very dangerous.
The bottom speaker grill snaps straight off. There are a row of screws under the screen around the screen bezel that must be removed. The bottom of the screen will become loose and the whole screen assembly slides up, like opening a window (there is a bracket under the bezel at the top of the screen that the bezel slides off of.) My screen took a lot of effort to disengage the top bracket - careful not to break anything!!!
Once the screen is off, put it safely aside. There is a mirror in the back that can be cleaned with a damp cloth (not dripping wet!). Remove a little dust at a time and keep washing the cloth out between cleanings. Be very gentle. If you push on the mirror it could break If its never been cleaned there is sure to be a lot of crud.
Below the mirror are three colored lenses. CAREFULLY use a clean lightly damp cloth to wipe each one. Don't mess with any of the adjustment screws and levers on the lenses.
Before putting the screen back on the TV, carefully clean it with a damp cloth too. Slide the screen back over the top bracket, put the screws back in, and pop the speaker grill back on.
Its a good idea to readjust you convergence too.
When I cleaned my set, I was amazed at how bright and sharp the picture was!
Be Careful!
Jan 07, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
The screen on my coldwater feed keeps rusting up
No, don't poke it through. It will clog elsewhere. Clean the intake screen completely. Buy a $3.00 in hose screened washer. Put it in the hose end connected to your taps. The reason cold clogs and not hot is that the rust settles in the bottom of the hot water tank and doesn't get pushed thru the lines. The cold water is a direct feed. Clean the newly installed screen monthly as your supply taps are way more convenient than the connections to the water inlet vavle at the back of the machine.
Jun 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Samsung VP D31 stopped recording video - just black screen
my samsung vpd230 has stoped recording, just a black screen,
would you also explain what a ccp is,also the words memory stick keeps keeps appearing.thankyou
Apr 06, 2010 | Samsung VP-D31 Mini DV Digital Camcorder
REAR PROJECTION GREEN SCREEN
dust can cause this, keep your tv clean especially since dust gets into the little vent and can keep the heat from the bulbs from escaping. If that doesn't help let me know how long it takes to get a green screen again.
Feb 06, 2009 | Sony KV-20M10 20" TV
Lint screen light is on, dryer won't start!
If you use dryer sheets they create a wax coating on the lint screen,even tho it looks clean,use dish soap and hot water to remove this,dry it then put it back in and try it.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 30, 2009 | Bosch Nexxt WTMC 6500 Gas Dryer
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Beaumark Whisperwash portable dishwasher has pile of macerated food scraps behind screen at bottom rear of machine. Dishes have "grit" stuck to them after cycle complete. Think the built-in...
That screen is held in place by two screws. Remove the screws, pull out the screen, clean it and put it back. You should perform this cleaning periodically to keep your dishwasher running perfectly.
Gina
Jul 11, 2008 | Dishwashers
Spyware infestation
This website should help you out. It's really good, try it. It's free. http://www.microsoft.com/athome/security/spyware/software/default.mspx
Jun 30, 2007 | Samsung 997DF 19" CRT Monitor
Nintendo DS Console Logo
42 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
