Question about Sony KP-53S65 53" Rear Projection Television
Sony KP-53N77 Had trouble with the blue colors being half an inch off from red and green, shadowing over. Went into settings and found out the blue alignment grid at the top was curled under and the words for the settings were out of line.Took out print boards and checked solderings. Finally had to move the blue grid down about one two inches to straighten the top grid and words out. Then moved the red and green down to match. The colors are cool now but my screen is two inches low, but still reaches the top of the viewing screen. Do you think my blue tube is bad you can look inside the tube and the right top corner had a wave in it. Not sure what to do or just leave it alone?
  • bigdummie59 Dec 31, 2007
    Thank you i'm an electrician and a repairman on restaruant and heat & air products, but i'm not sure i'll be tackling this one. Sounds like it could be bad. Got a great picture now, guess i should just ride it out. If nothing else i'll have an excuse to upgrade, any good ideas on a dependable product?
Well I personally like rear projection sets with tubes in them better than the new HD crap but Sony or Hitachi would be my choice if I had to buy one of the new format sets, good luck with it & Happy New Year, BMW Rider
Posted on Dec 31, 2007
    Novelist:
    Champion:
  • 232 Answers
Hi, you have a convergence problem, the IC`s and possibly a few precision resistors feeding the IC`s will have to be replaced, not an easy job if you haven`t done it before. If you are very proficient at solder work and can use a volt meter to check the resistors you can do the job but it isn`t easy for a lay-person, If you have more questions e-mail me back, good luck, BMW Rider
Posted on Dec 30, 2007
Why does my sony 45 inch screen have mostly green color?
the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
Kp-53n77 color 53
Try resetting to factory settings via tha manual at this link.
It will download onto your computer in PDF form.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP53N77&LOC=3
Mar 11, 2008 | Televison & Video
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
