Rear Projection Gateway HDTV with DLP,56"
Hi Gurus and Wizes,
I'm about to lose my mind. I bought a 56" Gateway brand RPTV 4 years ago,and now it's making the most annoying humming sound. So loud that it even bleeds through the sets own speakers. I called in a repairman(an HDTV specialist,supposedly) who informed me that the set itself was a Samsung manufactured for Gateway. He also said it was the color wheel that was most likely the problem. He said he'd contact Samsung and get back to me whether he could order the replacement part. Fine. He calls back the next day and says that I may as`well buy a new set! He said on this model that Samsung informed him in order to fix the problem,ALL the inner workings of the set would need to be replaced,resulting in a cost higher than what I had even paid for the set new!
I'm bummed because the picture on the set is still great,and I had just recently replaced the set's lamp---no small charge there either. Can you either verify what he's saying is true,or is there another solution or fix to this problem that wouldn't involve a complete overhaul?
  • frotslig Feb 03, 2009
    The TV is made by Vizio/Vivitek and the noise is probably from the color wheel. (That's what mine is.) It's a fairly easy replacement for around $80 for the wheel only. It can be replace without replacing the light engine but you have to be careful not to break the block for the ribbon connector from the light engine PCB. That's what I just did. The ribbon pulls out from the block and the block stays there.
    Now I'm looking for both.
    4 screws hold the color wheel housing in and 3 screws hold the wheel to the housing. Getting to it is a bit of a challenge if you're not mechanically and electronically proficient. It involves removing the light engine PCB before you can get to the color wheel housing. It will also require bending a metal tab just a bit that is located in front of the housing.
  • 232 Answers
Witzend, hate to be the bearer of bad news but he`s probably talking about the light engine and those dam things run 650-1150 just for the part, also, the last I knew the Samsung engines had been on national back order for the last 10-12 weeks, ( tells you something doesn`t it ) It`s ridiculous that you have to buy the whole light engine to get a new color wheel but that`s the way they do it, good luck, BMW Rider
Posted on Dec 30, 2007
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My 46" Samsung DLP Rear
It's possible that the DLP chip is going bad. I'm not sure how much it would cost to repair it. If you have the part number you can search for it on ebay and probably find it cheap. I couldn't tell you how much it would cost to have someone repair it, or how to do it. I do know that diagnostics typically cost around 100.
May 04, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have sound but no picture. The screen is black. I replaced the lamp and it's still not working. This happened a few years ago. I replaced the lamp and the tv came right on, but not this time. Any...
DLP tvs alots of times the board that call the Ballast board is also dead too,beside the tv projection lamp.The Ballast board only job is to ignite the projection lamp.
Mar 02, 2011 | Gateway DLP56TV 56" Rear Projection...
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My tv dont turn on and the power light is red
Hi if it's an LCD or DLP RPTV and tv is between 2-3 yrs most likely it's time to replace the lamp.You can find it on discount-merchant at low prices and OEM .God bless you!
Oct 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
The tv clicks on but no picture or sound
Hi if your tv is a DLP or LCD RPTV most likely it's a ballast issue which is the board that powers the lamp.It could also be your lamp if tv is between 2-4 yrs.God bless you!
Oct 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
White dots on samsung dlp
HI, these are the signs of a failing light engine. you will need to replace this engine soon. these distortions will worsen over time.
Jul 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR6768WX DLP TV
That humming sound is a sign that your color wheel is becoming or already is defective. If you don't replace it you might even lose picture in the future since it's part of the light engine system
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
