Question about Whirlpool Calypso GVW9959K Top Load Washer
Not recirculating Went through all the test scenarios, and I got the unit to recirc during the test. However, during a regular cycle, the machine will not circulate water into the load, and it continues as if the clothes are wet. -Water inlets clean -pump will recirc in test mode -pump will dump in rise only (test mode) -during test mode, "0d" appears in display instead of "00". Any help would be appreciated
  • cprooney Jan 15, 2008
    My Whirlpool Calypso only fills with water and them humms. It does not recirculate water nor agitate. Could you please tell me how to put it into test mode? Which buttons do I push to go thru diagnostics?
    Scholar:
  • 196 Answers
"0d" refers to an "open door" problem. Need to chceck the lid switch to insure it is functioning properly.
Posted on Jan 12, 2008
A/c recirculating light comes on when i first start up the 2004 gmc yukon xl will not go off until recirculating switch is pushed. Sometimes comes right back on and u have to reset it again
{: ) Just let it be as this behavior is part of normal operation. Observe for a while. Check again your mode settings, should not be in defrost or defog mode when recirc is requested. The recirc function is available only in face or bi-level mode.
If the recirculation switch is pressed into the ON position when the mode switch is in an unavailable mode position, then the recirculation switch LED will flash 3 times. If the HVAC control module detects a fault with the recirc door the HVAC control module will try to drive the actuator for a predetermined amount of time, to outside air, which is the defaulted position for the recirculation actuator.
Try settling on the face and bi-level mode. You can manually turn on or off the recirc function and observe some air change on the vents. When recirc is off (light off) outside air will also enter and it will mix with the cold air inside if your a/c is on.
The HVAC system also monitors the inside and outside temperature sensors and uses these inputs to control the opening or closing of the recirculation door. If the outside temp is colder, it may not allow recirc off, sometimes it may not even allow a/c function. You may also have a sticking door or failing actuator. If any of the approaches above doesn't come out well, you may proceed for a scan tool diagnostic test to be sure, if your HVAC system does have a trouble.
Aug 27, 2011 | 2003 GMC Yukon XL
Stuck in rinse cycle and the brew unit wont come
Allow the unit to complete the rinse cycle.
It may take several jugs of water to complete.
Feb 14, 2010 | Gaggia Titanium Espresso Machine
AC blows cold but when will not stay in recirculate mode
It is possible that your heater control valve is not restricting the water flow to your heater control valve when placed in the AC position.
Aug 28, 2009 | 1995 Ford F150 Styleside Regular Cab
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
2005 Toyota Corolla air conditioner is cold but
The air flow does not 'increase' with the recirc button pressed. The fan motor blows at specific speeds, no matter whether fresh or recirc is selected. The recirc feature is there so that you do NOT admit 'fresh/hot' air from the outside into the AC box. In short, the recirc feature is to re-use, or, recirculate the existing air in the car. When it is properly working, on a hot day, the recirc selection should drop the internal temperature at the center air vent about 6 degrees lower than with the fresh selected.
Jul 18, 2009 | 2005 Toyota Corolla
Recirculate button not working
either your heater conrol head with the recirc button is bad, or the motor that opens and closes the inside/outside air door.
Jan 31, 2009 | 2006 Ford Focus
Fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
Dec 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
94 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
