Question about RCA RS2531 CD Shelf System
Can't get the cd door to open
Tell me please how I get the door to open without breaking it. This is frustrating......
Mine did the same...with mine it was because one of the cd's came out of the carriage inside the unit... i popped of the see-through top on the unit, put the cd's properly in the carriage and it opened right away... it may say "error" on the front screen
Posted on Oct 05, 2008
MY WINDOWS HAVE NOT WORKED IN FOUR YEARS IN MY FORD EXPLORER, I WAS TOLD THAT MY REGULATOR AND MOTOR WAS GOOD,AND I NEEDED A MASTER SWITCH BUT WHEN I PURCHASED THE SWITCH IT STILL DID NOT WORK,I CANNOT...
henryhand8, I can't tell you which fuse is for the windows but it is located in the passenger compartment fuse box. Try testing all the fuses and replacing any that are bad. The relay is there as well. What I can tell you is that a big problem with this is the wires that go from the door to the vehicle. There is a bundle of wires that come out of the door, you can see this with the door open. You need to cut open the rubber boot that protects them and look for any broken wires. This happens because this door is opened and closed the most which bends the wires back and forth until they break. As you said the regulator and motor are good and the switch is new. Repair any broken wires and replace any bad fuses. Good luck with this.
May 12, 2011 | 2002 Ford F150 Regular Cab
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS TO OPEN THE DOOR. IS DIY REPAIR FEASIBLE? HOW MUCH WOULD IT...
DIY repair is possible. you must remove door panel inside and have window up to access the handle linkage from inside. The handle that you pull up on from outside, and the housing that surrounds it are usually a one-piece make. This work is tight and frustrating, take your time, look at how it fits together before you take it apart. Take pictures, make a drawing. I did this job on my celica and it was tough, but I took my time and got it done right. I can't tell you how much a shop would charge to fix it. smaller hands would have made things easier. . .lol. Good luck
Dec 09, 2010 | 2001 BMW 5 Series
My girlfriend put 2 CD's in the stereo by accident & now the door won't open. Is there a way to get the door open without breaking it?
Yes there is you have to unscrew all the screws in the back and sides.. open the cover and you should be able to access it
thank you please let me know if this helped
Jul 07, 2009 | Emerson MS3111M Shelf System
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Door to load cd's wont open or close without help.
Hi...
I use a place called
www.studiosoundelectronics.com
or
matelectronics.com
Studiosound will even tell you how to measure your belt if you need to
Godspeed,
Scott
Dec 16, 2008 | Yamaha CDC-845 5-Disc CD Changer
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Cd player keeps opening with cd in it
Some small item would appear to be obstructing complete closure
With the drawer open take a good look in side.
Also near the  open button you  should see a small pin hole[sometime on the back of the unit]
 This is the emergency eject device in case you get a jam and is operated with the end of a paper clip.
give it a poke with the drawer open  then again closed
See what happens
Oct 20, 2007 | Memorex MKS5001 Shelf System
Dvd door
I had the same problem. It started after I plugged a PS2 into the system using the A/V cable ports in the front. I discovered just by unplugging the cables the door opened again.
Sep 13, 2006 | Zenith XBS344 System
RCA RS2531 CD Shelf System Logo
149 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
