i have two 1000 watt ballasts wired with tandem capasitors powering two 1000 watt metal halide bulbs. i would like a diagram of the wiring to make sure it is all correct. this is wired on a 480 line. the two ballasts are different both have two wires one has a 480 line and a cap line the other has a 480 line and a lamp line. ballasts come from advance lighting numbers 71a9377 and 71a9378 using two aerovox 2779-mf
tandem wired capasitors powering two thousand watt metal halide bulbs
I have this device coneccted to a Air Conditioning unit. The Circuite Breaker sounds and it is quite...
(More)
I have this device coneccted to a Air Conditioning unit. The Circuite Breaker sounds and it is quite anoying. Why does is sound? it is a shrill sound
I have a 2004 Nissan Almera SE. During the recent bad weather the drivers side front and rear...
(More)
I have a 2004 Nissan Almera SE. During the recent bad weather the drivers side front and rear footwells have become saturated with water. However my regular mechanic and myself have no idea where the water is coming in. Any Ideas?
Motorguide thruster 54 will run fine on two low speeds but will cut out (turn on and off) on three...
(More)
Motorguide thruster 54 will run fine on two low speeds but will cut out (turn on and off) on three higher speeds.
My 2008 71 lbs of thrust 24 volt system is not recharging prooerly, I have replaced one battery in...
(More)
My 2008 71 lbs of thrust 24 volt system is not recharging prooerly, I have replaced one battery in loess than 20 hours of total usake. How to get it up and running
