Computer wont turn on
We moved the computer from one room to another room and now the computer wont turn on.
We opened up the computer and the power light on the motherboard turned on when we plugged it in.
  • chaz101 Jul 01, 2008
    emachines t3958
    won,t turn on
    start button does nothing
    lled on mother board comes on
  • sanjuanyet Nov 25, 2008
    won,t turn on
    emachine T2862
Ive a vast experince on power supplies an mother boards;hp;compaq ;dell.mostly the problems are very minor.you post 200 kshs;call me on +254 0726756868,mike an give the tip thr;ma phone.MPESA SAFARICOM
Posted on Aug 10, 2008
    Problem Solver:
  • 5 Answers
Most likely the power supply went and took out the motherboard as well. Read the link
http://www.geek.com/forums/topic.php?id=33947&page
Posted on Jul 17, 2008
  • 32 Answers
So, lets say that you have double checked all cables, and everything is plugged in properly. When you hit the power switch on the case, do you hear the computer start then shut down several seconds later? Does the computer refuse to do anything but power a motherboard LED? Also, did the computer (or the person carrying the computer) bump into anything while moving it? The most minor bump can cause many problems.
I would try replacing the power supply with another one from a working PC, but just to make sure that the power supply unit is the problem. If it isn't, make sure all heatsinks are locked down appropriately and making full contact. Other than that, I don't know what you can do.
Posted on Dec 31, 2007
Moved my computer to a different room and now it won't turn on
1) Make sure the plug is inserted fully
2) Make sure the power switch on the case is in the on position
Apr 13, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
Tower does not power on. I turned computer off to move to another room and plugged back in and now computer won't power on. I have tried another working power cord and still doesn't power on.
This is most likley due to your power pack. it will need to be replaced. here is a guide on how you can do this.
http://www.fonerbooks.com/r_power.htm
Any further questions feel free to ask.
Nov 22, 2010 | Dell Inspiron 531s Desktop Computer
I need assistance with the front panel cables for Intel d915gav. My computer wont turn on. I dont know where to connect the connections. & I dont know why my computer wont turn on. Please help, I need...
Follow this link to the spec sheet for the board. Make sure the wires running from the inside of the front cover are plugged into the correct pins.
http://downloadmirror.intel.com/15196/eng/D915GAV_D915GAG_TechProdSpec.pdf
Oct 17, 2010 | Intel D915GAV Motherboard
Moved my computer to another room and when starting up the monitor has no power. I tried changing cords and outlets and still no power. Is this the end of the line?
It may have been coincident. For a 4 years old monitor, the power supply may have failed.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Gateway FPD1950
Moved the router to a different room and now it wont work
check the physical connection to the router. Make sure that the modem and computer are connected properly and there is no loose connection.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 22, 2010 | D-Link AirPlus DI-524 Wireless Router
Unhooked and moved my computer to another part of my room and the monitor now comes on with the power saver display and button is blue, then power saver display goes off and button turns yellos light and...
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
Sep 29, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Wont turn on, nothing.... Power supply is good
Replace the power-cord.
Wait until midnight, and turn out all the lights in the room, so that's dark in your computer room.
Turn on the monitor, and see if you get any light and/or any lamps (green? yellow? red?)
Try a different monitor attached to your computer.
Try your monitor on a different computer.
Sep 10, 2009 | Polyview PT-525A Monitor
Keyboard not working-no power
Double check in the ends of the plug to make sure you did not bend or break any pins when you plugged them back in.
If you did then it is quite possible you need new and that you should also check the sockets on the back of the computer to make sure they are not damaged either.
Aug 17, 2009 | HP Computers & Internet
HELP! My HP Scanjet5470C worked PERFECTLY - not anymore
u'r scanner have to turn on first for the computer regocnize
try another power outlet, if the scanner turned on, it means the power outlet u used now is poor...
u can check the power adapter first
Mar 12, 2009 | HP Scanjet 5470c Flatbed Scanner
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Computers & Internet Logo
351 people viewed this question
Alun Cox
David Payne
David Payne
