Question about Baby Gear
Car overheating my bmw 325i (1992) is overheating when sitting idle when i go to take the radiator cap off it just boils over but when the car is moveing the temprature goes back to normal just lookin for some advice on what to do
  • geeweezy Jan 03, 2009
    overheated car, i added coolant and now it can't start help me for a solution
The car wont start after being overheated,
Posted on Jan 03, 2009
    Problem Solver:
  • 17 Answers
Yikes! Don't ever take the radiator cap off when the radiator is hot or even warm. The coolant is under pressure, and comes out quick when you open the radiator.
Also, it's best not to drive too far on an overheated engine, because that can cause internal engine damage that's expensive to fix.
There could be a number of things wrong. The easiest one to check is your coolant level. The operator's manual will give you good instructions on doing this properly, but usually you wait for the engine to be cool, and then you check the level on a reservoir, adding fluid to it if necessary. (not directly into the radiator)
You could also have a blockage or air bubbles in the radiator or other damage that's keeping it from cooling effectively. You may be able to flush your radiator and refill it with coolant. Again, see the owner's manual.
But from your symptoms, it sounds like the fans are having a problem. There should be one or two fans mounted behind your radiator to keep the air moving when the car is idling. The fans, their wiring, or the switches that control them may be faulty.
You can try following the wires from the fans to the wiring harness to make sure they aren't broken, have damaged insulation, or unplugged. But you might need a mechanic to do more advanced troubleshooting.
Also, some models of cars can run their fans even if the ignition is turned off, so be careful when working around the fans; they can turn on unexpectedly.
Posted on Dec 30, 2007
Why is the car overheating?
Your radiator cooling fan may not be working properly
Aug 22, 2014 | 2003 BMW 325i
Why is my 2001 bmw 325i still is overheating after i changed the water pump, thermostat and purge the system?
Well Michael put your hand on radiator upper hose and then the lower hose right after car warms up and just starts overheating is there a temperature difference if so one of two things is going on thermostat not opening even though it is new or there is still an air bubble in the cooling system if nthere is no difference and still overheating might have to explore headgasket being blown
Aug 05, 2014 | 2001 BMW 325i
2003 BMW 325I overheating
Water pump or head gasket?
Jul 14, 2014 | 2003 BMW 325i
I have got a BMW 523i and i have just realised that it overheated yesterday because i have been using the air condition the whole day!! What that could be!! Still the thermostat?? Its okay if the air con...
Could be the radiator is full of bugs or normal road filth that accumulates. How is the coolant level in the radiator. Fill it if low. Were you stalled in traffic? Were you at high altitude, like in the rocky mountains or appalachian mountains. Check radiator cap. They are relatively in-expensive considering the job they do. The cap pressurizes the fluid in the radiator and prevents it from boiling out at higher altitudes or higher temperatures.
Sep 29, 2010 | 1998 BMW 5 Series
Overheating when driving no mixing of the coolant and oil
The three most likely thing's cause overheating are faulty thermostat,electric fan or clogged radiator. Only at has been overheat so much it boils dry that it will cause engine trouble. Most common problem's are blown cylinder head gasket or a cracked cylinder head.
mixing coolant and water depends on where the gasket has blown or head is cracked. You will first need to check if it actually is overheating. The reason is. If the head is cracked or gasket blown then you can get a false boiling which is compresion from the cylinders blows through the crack in the head or gasket causing the coolant to blow out of the radiator cap.Fill the radiator to the top leave the cap off then start the engine.If the water blows out then you will need to remove the cylinder head check the gasket is ok. If its damaged replace if not get the head checked for crack's. If no water blow's when you start it check the thermostat is working properly. To check the thermostat put it a in a saucepan cover it with water bring the water to the boil. It should open before the water boil's but near boiling-point. If its ok then start the engine again leave it running until it boils and check the fan is running. If that's ok then its radiator problem. Their is no way to check if the radiator is ok you will need to get a new one. One last point. If the cylinder head or gasket are faulty it was caused by overheating so by just fixing the cylinder head problem is not a cure it will overheat again. Check the three things I mentioned at the begining and told you how to check them. Hope this help's. Cheer's
Aug 16, 2009 | 1992 Ford Explorer
Overheating
Have you tried the 8 mm bleeder screw on top of the thermostat housing? You may have air trapped behind your thermostat. Also, overheating can be caused by a collapsed lower radiator hose. If it's soft and you can squeeze it together, then under acceleration it closes down on itself thus preventing the flow of your coolant. Also check your radiator cap. It's supposed to be a 1.1 Bar cap but if it's not functioning correctly, by having to add coolant to the coolant reservoir bottle or the coolant overflow bottle overflowing, usually says it's the radiator cap. These are the simple fixes that you ,may have overlooked.
Good Luck,
~Stillin~
Jun 05, 2009 | 1992 BMW 3 Series
1992 bmw 325i, when fule tank gets to quarter it runs real rough
i have a problem with my 325i iy shacke in idle i give it gas sound good and go fast just in a stop shacke agian??????? wtf is up with it.......
May 19, 2009 | BMW 325 Cars & Trucks
Overheating
I think you need to do a cheap and extremely accurate test.Its called a tk head test and it determines wether you have head or head gasket problem.If you could eliminate that part as being the cause then that really only leaves a couple of things left to check.A blocked radiator or an air lock.Maybe a faulty radiator/expansion tank cap not able to maintain correct pressure
Oct 19, 2008 | BMW 325 Cars & Trucks
Open Questions:
I'm I dropped my necklace inside my 2018 Camry XSE & I finally saw it today a few weeks inside the lining of the drivers seat belt buckle. Can you tell me how to retrieve my necklace? Thanks! Denise My necklace is inside the lining around the "stem?" Of the seat belt buckle down inside a hole. It's a white gold necklace but appeared to me that it's laying on top of something silver? Possibly some type of track inside the assembly. Honestly I have no idea what I'm talking about. I was excited when I saw it since it appeared as though it could be easily retrieved and it doesn't look like it's very far down inside the lining of the buckle either, so since I have tiny hands I thought I might possibly even be able to get it out with only my hand. Sadly I was mistaken. Next I took some thick, heavy craft wire; first thing I thought of bent it over & made a hook on on end? I'm no fisherman but it seemed that logically it should work? I should be able to catch the chain in the hook. With the fabric of the lining being a charcoal color, inside the lining even darker. Inside a dark car with only an over head light, trying to hold a flashlight while necklace fishing in over 100 degree temps, though I'm stubborn and didn't want to. The heat did finally convince me I had no idea what I as doing and the chances of my catching my necklace at that point much less actually reeling it in safely were probably few and far between. So I'm back to searching the internet yet again. Ha! If you're wondering why I'm going to such lengths to retrieve a necklace, I bought it the day my first grand baby was born and it has her name and birth information engraved on it. It's the sentimental value for her DeDe that makes it so special and why I want to get it back so badly. I'm very much appreciative of anything you can advise me to do to help me with this process. Thank you so much, Denise Tallant a/k/a Stella James's DeDe
Sep 24, 2018 | Baby Gear
Baby Gear Logo
193 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
