Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin cycle noise
I have a 3 years old Whirlpool Ultimate Care II washer. In the last two weeks when the spin cycle completes, the machine makes a very load noise ( more like a load dissipating rumble) and then begins to stop. The noise is very loud and scares the my dog every time the spin cycle ends. Got any ideas?
  • 1 more comment
  • jwattila Dec 31, 2007
    The basket does not move up or down. However, the drum does move side to side about 1.5 to 2 inches with very little resistance.
  • Anonymous Jan 06, 2008
    3 yr. Ultimate II - Ours is noisy, seems out of balance and tub seems very tight, won't spin fast enough to extract water. We have taken off the top ring & agitator, but can't get the spanner nut off to remove tub. The pump impellor is clear. Can you tell us what is wrong or what to do?
  • Anonymous Mar 14, 2014
    the washer will not complete a cycle without becoming unbalanced regardless of the size of the load or the speed of the spin
    President:
  • 1,314 Answers
Pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Posted on Dec 30, 2007
  • robert samples Dec 31, 2007
    i think that your inner tub is getting loose pull the center dispensor cup on the agitator i think there is a cap there pull it to then you should see a bolt remove it and take off the agitator then remove the other two peices and you will see around spanner nut thats what you need to tighten there is a special tool for this bot you could use a short handled pipe wrench try to get it as tight as you can but if you cant get it tight enough to lock the tub you will have to pull the tub and replace the spinning tub block if it gets that far then reply to me and we will go through it step by step
  • RBinWA Jul 20, 2012
    I have what appears to be the same problem, however when I try to remove the bolt under the cap, the wrench driver I have will not allow me to put enough torque on it...should I try and force it with a different tool?
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud Noise at the End of the Spin Cycle
some item has fallen down between the outer and inner wash tubs? remove it
May 20, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
475 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
