Question about JVC SR-V10U S-VHS VCR
Hook up to computer
How do I do it and do I need a specific piece of hardware in my computer
  • 619 Answers
Install the tv out cardw/cd or audio and video tv out for video editing together installation cd.
Posted on Jan 01, 2008
What is a computer driver
Drivers are software that is installed on computers that allow hardware on computers (audio, video, connected devices like keyboards and mouse, etc.) to work with the computer... Usually, when you hook up a new piece of hardware to your computer, the computer sets up drivers so it will work. So, there are alot of different drivers on your computer, depending on what your computer connects to.
Jun 02, 2017 | Computers & Internet
Hello,Help,my Compaq Presario 6000 won't boot, turns -on starts it's POSTthen massage...WINDONS DID NOT START SUCCESSFULLY RECENT HARDWARE ,SOFTWARE CHANGE. no changes made. the screen goes black...
Hi Chas,
sounds like you have a piece of hardware that has a bad driver. If you connected something recently, try disconnecting it and then start your computer. If it starts, then you will need to find the correct driver for it before you attempt to hook it back up again.
If that does not solve the problem, try unhooking all hardware, except for the hard drive with the operating system on it. If it starts normally, then you can turn your PC off and hook up one piece of hardware... start the PC... turn it off again... hook up another... start the PC... etc. until you find the hardware that is causing the problem.
If it does not start with only the operating system hard drive attached... then, the hard drive may be defect. You can take it out and put it in a USB casing and hook it up per USB to another PC... if you see the data on it, it should be ok (just in case, this would be a good time to backup any data on it that you may need). If you do not see the hard drive in Windows explorer then it is probably defect and you will need to purchase a new one.
Hope that helps
Mar 14, 2013 | Compaq Presario 5000 PC Desktop
Hooked up gateway but will not respond to windstream speedstream 4200
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
Jan 15, 2013 | Gateway 300 C PC Desktop
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
1) Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:Startup using Last Known Good Configuration to undo recent registry and driver changes.Use System Restore to undo recent system changes.Roll Back device driver to version prior to your driver update.
2) Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
3) Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
4) Return hardware settings to default in Device Manager. Unless you have a specific reason to do so, the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
5) Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
6) Use a system utility tool like Reginout for an instant fix.
Apr 27, 2012 | Dell Computers & Internet
What is the drivers
Drivers are software programs written by a device manufacturer for components (such as a sound or video card) which, when executed, enable the device to communicate with your operating system. Most components come with a driver CD that enable you to install the drivers on your hand drive per the manufacturer's instructions.
If you find this information to be helpful to you, please rate my response to you on the FixYa website.
Nov 28, 2010 | Computers & Internet
I need a driver
Are you talking about a driver that interconnects to your computer (that is: a piece of hardware), or are you in need of the set-up software disc that goes with the copier and tells the computer how to understand what the copier wants to do ? You can always contact the manuf. of the copier, but they may want the original owner info in order to assure that it is not stolen. You can usually find this at a computer hardware store or a repair shop for such items. If it is a interconnect driver that you need, this may be specific to the computer more so than to the copier. The only way to advise you completely, is to know more about what you have or do not have, the age of your computer . If you still cannot solve te problem with the help your received so far, you will need to resubmit your problem with additional info. Goodluck< macgivor
Jan 02, 2010 | Toshiba e-Studio16S Copier
The router will not configure on my pc. i keep getting error code 312. it says cannot find network adapter.
The Router is an "external" piece of hardware, outside of your computer,
while the "network adapter" usually is an "internal" piece of hardware, inside your computer.
If Windows has not loaded the device-driver for your specific network adapter, then there is no way for Windows to communicate THROUGH the (non-functioning) network adapter to the external router.
click Start
click Control Panel
click Classic View
click System
click Hardware
click Device Manager
click the '+' to th left of Network Adapters
If there is nothing listed, then Windows has not "found" your network adapter. If there is a yellow "mark" on the network adapter, then the device-driver for the network adapter has a problem.
Take your computer to a "geeky" friend, or to a qualified technician, in order to install the correct device-driver for your specific manufacturer and model of computer.
Nov 25, 2009 | Linksys WRT54G2 Wireless Router
All the wires on my computer are not hooked up
All I can tell you is to read up on specific computer hardware components. Get a few magazines on PC's and read them. Its not something that is easily explained without reading up on.
To get this one together read over this:
Building a computer is half reading and half hands-on.
Jun 15, 2009 | Compaq Computers & Internet
I need dirvers fr winxp
Go to your pc manufacturer's website and search for the drivers. You will need to install a driver for each piece of hardware that match your operating system. Drivers are specific to you hardware, not OS.
Apr 30, 2009 | Computers & Internet
Installation of the drivers
Drivers are hardware specific, meaning that they are different for each piece of your hardware..are you looking for drivers for a specific piece of hardware , or are you looking for all of the drivers for your laptop?
If you are looking for your laptops drivers, you can find them here by entering your laptops model in the search box:
Sep 29, 2008 | Compaq Computers & Internet
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
