Question about Toshiba 55H70 55" Rear Projection Television
Toshba CF27E50/CF30E50/CF32E50 My rear projection TV with about numbers listed on the owners manual, suddenly went weird the other day. There is an arc from the middle of the picture on bottom to the left and the red and blue are split. Across the top the red/blue or convergence is like a vibration and not aligned. After reading on this I would guess it is the convergence IC or IC's. Can these be bought online or from somewhere close to me in Dallas? Do you think I will save alot from letting a repairman do this? Should I expect this to happen again? The TV is only 5 years old. Thanks for any help.
  • natedawg9640 Jan 06, 2008
    Hi, i have a mitsubishi rear projection. i think it's a 50 inch. i bought it used from a friend and it seems to have developed the same problem. first off. where do i find the serial numbers, and second... i am fairly handy and able to solder, but i've no clue what components are what inside a tv. Is there a schematic or possible a step by step how to for this fix?
  • 373 Answers
The convergence IC needed are STK 392-110 two of them and possibly a resistor or two If you don't know how to unsolder and solder I would suggest an honest repairman. most Parts distributors won't sell unless you have a business but you could try anyway. A volt-ohm meter is required "IF" a resistor needs to be checked or is burned. Convergence IC's are a common problem with all projection tv's. It may last another 5 years especially if you don't buy the generic ic's
Posted on Dec 30, 2007
based on model listed here visit the Hitachi site or Google the model number with "manual" to locate a owner manual for this set.
Jun 12, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Need the code for toshiba tv
Google search with the model number of the unit for "manual" for a owner manual with a possible list of codes to try. Remember that universals have a limited number of codes built into them--may or may not have the one you need.
May 23, 2012 | Toshiba Televison & Video
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
Need an Owners manaual for a tv
Try Googling (hitachi)(50EX11BV)(manual) without parens.
Sep 29, 2017 | Hitachi Televison & Video
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Problem with phillips 60 projection tv
Possible cause could be a defective HVG (5904). Replace part with part number listed in this service manual.
Possible cause could be a defective Convergence
Amps (7044 and 7045) on Small Signal Module.
Replace part with part number listed in service manual.
Jul 29, 2008 | Philips 60PP9202 60" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
"my tv just went out"
Most likely your lamp has failed and your owners manual will show how to replace the lamp.
Nov 21, 2007 | Zenith D52WLCD 52" Rear Projection...
T.v. just went out i have a zenith 52" is thier a reset button or something?
Most likely the lamp failed, check your owners manual for instruction on the lamp replacement.
Toshiba 55H70 55" Rear Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
