Question about IBM ThinkPad R40 2897 Notebook
Monitor blurry or black
The screen sometimes gets very blurry, so much so that I can see some sort of coordinate or line that seems to be following the mouse around (specifically, it appears on the same "row" of the screen where the mouse is, but on the other side of the screen), the text is illegible and shaking. Sometimes white lines go up and down the screen and then the screen blacks out, with a few white lines near the bottom. The blurriness/blackouts usually occur when I place the laptop on a surface that is not perfectly flat, or when I am moving the laptop, though it sometimes seems to happen for no reason at all. Someone told me that when it was blurry I could go to Display, lower the resolution and then raise it again; that worked a few times, but doesn't seem to, anymore (and of course it doesn't help for blackouts). Right now, the only thing that helps is rebooting.
I've had the laptop for a while (nearly 4 years) and would probably prefer to replace the whole thing than just the monitor--is it time for a new laptop or is there something I can do?
  • 62 Answers
The problem could be with the LCD or the Video chipset. Either repair is expensive. I would figure about $150 in labor plus part cost. You can try ebay to get an idea of the part cost.
At 4 years I would be leaning towards purchasing a new laptop.
Posted on Dec 30, 2007
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Blurry Screen
If you're using a VGA cable (a.k.a the blue plug) you'll have to use the Auto-Adjust feature on your monitor.
Jul 13, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
HI I WOULD LIKE TO ASK U A QUESTION MY COMPUTER SCREEN COLOR IS BLURRY AND SOMEM AREA I CANT SEE AT ALL WHAT IS THE PROBLEM WITH MY LAPTOP?
Is it laptop screen or monitor?
If Monitor,
you can adjust it by your self.Remove the power cord first!!!
Open the monitor case, then you can see the Boards, after that, check on cable that attached to the Monitor tube, sometimes the color is red,then follow it down to the black plastic box. this is Fly Back transformer, check on the transformer body, can you see the "screen" and "focus" screw, if yes, you can adjust it.
To adjust it, you need to turn on the monitor (without the case) and computer unit ( Monitor and Computer connected ), after all is good, then carefully adjust the screw for "focus" using the "+" screw driver, twist it around slower until you get the desired focus on the screen, then after all done, turn it off then put on back the monitor case.
If Laptop screen,
There's nothing that you can do, because the LCD screen is delicate, and my suggestions is better find a good service center to fix it.Seems like the inverter boards inside the LCD is damaged.
Hope this useful.
Feb 22, 2010 | Office Equipment & Supplies
The screen is blurry on the top, bottom and sides, but the middle is somewhat clear. how can i fix it? thank you for your time!
open the monitor a black EHT will found see the preset set it by screw driver on line see result on the screen the name on preset is FOCUS
Nov 13, 2009 | IBM E74 Monitor
Black line down lefthand side of screen about 1" thick
The monitor is old. It could be slightly adjusted. But when you start getting lines, soon the image becomes blurry, and during CRT death the Cathode Ray Tube radiates 100 times the radiation of a healthy monitor.
Sep 06, 2009 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Acer screen is black or blurry
If you've connected an external monitor to your computer and the image is coming up fine then that means your video card on the motherboard is good.
The only other parts it could be is the LCD Flex cable that connects to the LCD screen to the motherboard, the LCD Inverter that powers the LCD screen or the LCD screen itself. Usually you can find a used screen that is complete with all those components on ebay.
Jul 30, 2009 | Acer Computers & Internet
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Pixels?
Seems your screen is about to die unfortunately.
To verify this see if you can connect your PC to another LCD screen, if the problem persist it is not your screen but your PC.
In case it is your PC, just clean it out (blow compressed air to remove all dust from your casing) and reinstall driver displays.
Otherwise i'm afraid a new (or used) monitor will be mandatory...
Aug 08, 2008 | Acer AL1914 19" LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
IBM ThinkPad R40 2897 Notebook Logo
137 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
