Question about Epson Stylus CX4800 All-In-One InkJet Printer
Printing pictures from memory cards
I follow the instruction for cx4800 and after installing the flash card press the start collor button as per instruction . Error light comes and all of the green lights are flashing to. We have printed pictures defore. Can you help.
  • Epson Master
  • 1,879 Answers
>remove the flash card - try making a standalone copy
>try another card
Posted on Jan 03, 2008
Will not take pictures camera saying full when memory card is not full also when no memory card is in camera
Your camera is talking about its internal memory. If you want the card to start working, you must get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions.
Apr 04, 2011 | Cameras
Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
On some cameras, once you use the internal memory, you must format it and completely erase it before a regular memory card will work. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, never use the internal memory again.
Feb 17, 2011 | Intova CP9 Digital Camera
Control Button Problem
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory and then promise yourself to never use it again.
May 11, 2010 | Cameras
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
Can't move photos from internal memory to memory card
Yes, it can be done. Here are the steps to copy them over:
1. Turn on your camera
2. Press the button to view the pictures you have taken (the button that has the green sideways triangle with the green square around it).
3.Press the Menu/Ok button
4. Arrow down to "Copy"
5. Press the Menu/Ok button
6. To copy the photos from the internal memory to an SD card simply hit Menu/ok button again.
7. Arrow down to "All Frames" and then press Menu/Ok
8 It now asks you to confirm. To continue copying the pictures over, press Menu/Ok again.
9. It will now begin copying your pictures over.
There you go. Hope this helps!
Jul 16, 2009 | Fuji FinePix S700 Digital Camera
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Hi KarenB,
Not sure if anyone ever got back to you on this but i just had the same problem then googled it and found this
Yes, the [BACKUP] feature will transfer files from the camera's internal memory to an xD-Picture Card™ flash memory card. It does not delete those files from the internal memory. To perform a backup, insert an xD-Picture Card flash memory card into the camera and then turn the camera on. Press the [MENU] button. Press the Right arrow button to select the Setup icon, and then press the [OK] button to enter the Setup menu. Use the Up or Down arrow to select [BACKUP], and then press [OK].
Dec 03, 2007 | Olympus SP-700 Digital Camera
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
