Question about Jetway MiniQ 765Twin (miniq765twin) Barebone
Blank screen and never starts.
My jetway is never starting up at all. I moved Memory, cooler and CPU from a functional unit so there schould be no problem with those. It just never starts.... still the LCD is working. I have also tried to install a new AGP video card and the screen is still blank when starting up.
I can not tell when this started since I just got it myself and the previous owner claims it works. The CPU I am trying to use is an AMD Athlon 1900.
  • 46 Answers
Try a new power supply
Posted on Jan 23, 2008
Power light on back of Inspiron 518 is on but computer will not start by pushing start button on front panel.
Things to check !..
1st check the CPU fan to be functional cause its failure will lead to this behavior .
2nd check the ram memory ...If it has issues with the ram memory it may not boot at all ..or try to boot but only the fan will start and will make some warning beeps and go in a starting loop ..
3rd is a CPU failure..In this case the computer may start or not ..and in case it starts only the CPU will spin ..but nothing on screen .
In the last case check the wires from the source to the board ...the plugs to be well inserted and the source itself ..(measure ti with something ..or use it in another computer to see if ti is functional ..
Please rate my answer if it helps..have a good day !
Sep 19, 2011 | Dell Inspiron 518 Desktop Computer
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
My mother board asus p5v800-mx was having a bios corrupted.. it only display starting bios recovery..
Try these options if you mainboard is not booting!!
1. Clear CMOS. (Remove the CMOS Battery)
2. Remove your memory cards and video card, try to clean their golden connectors with a rubber, then reseat them back.
3. Remove the CPU cooler out, add some thermal paste to the CPU surface, then reseat the cooler back and keep the cooler tightly installed.
4. Keep the necessary components(CPU, one memory) onboard for a test.
Finally, recommend you to replace a BIOS battery to have a test.
Hope it helps.
Oct 11, 2010 | ASUS Computers & Internet
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
My heat sink got dirty and caused a thermal event alarm (overheated) the computer will shut down when the cpu is taxed. do i need a new cpu
No, if the computer will start and it run bios screen and boots into windows
the cpu is fine, you need to get a better cpu cooler.
Buy a better cpu cooler for your socket, coolers are designed for the Socket that the processor plugs into.
Go to Newegg.com and llok for a cooler, you will see reviews by people
and if they liked the cooler, there are little eggs next to the product
is it has high ratings, you will see what I mean when you look at the site.
The page I posted is already on the cooler page, just llok to the left side
and look at sockets and pick your socket out to look at coolers for your system.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Feb 07, 2010 | eMachines T3516 PC Desktop
Computer continiously ask for reboot
DFirst thing to do is to UNdo everything you have just done: Memory Upgrade and CPU Cooler. If normal operation returns, try the upgrades, one at a time, to narrow down the source of the problem. I suspect the memory, as a DIMM chip not correctly set up will cause this problem. Let me know what it does, please? jaye.ellen@gmail.com
Dec 12, 2009 | ASUS P4SP-MX Motherboard
2 short 6 long beeps, whats the problem? nothing on screen, no other signs.
Check your VGA Card it's properly connect and your memory module, maybe one of that is not functioning.
If still have that beeps then change temporarily your VGA Card with another. As long as you see some appears on the screen then it's good luck.
Please rate us!
Oct 05, 2009 | ASUS p4p8x-uay Motherboard
HP6720s -windows vista- Laptop: Blank screen -does not load
Did you make recovery disks? It is possible that your cpu cooler fan has died inside of the unit
Aug 03, 2009 | HP Compaq 6720s PC Notebook
Unable to start - do not get post.
First of all that is too old system that you are using, problems can be your CPU's golden legs are not connected well on motherboard, second your ram memory is not working good, maybe is slower or faster than that motherboard can receive.
First of all disconnect everything from motherboard ...if it does not work :
1. Remove cooler from cpu
2. remove cpu from socket, turn around CPU and look at those golden legs if they are moved aside
3. if they are moved turn them back on the line use needle or small pocket knife to do it and do it carefully
4. carefully place CPU back in socket
5. put CPU protective grease
6. put back cooler on CPU
7. remove ram memory from slots
8. look at the golden legs if there is no broken use clean cotton swabs and pure medical alchohol and clean the ram golden legs put the ram back in slot
9, do the same with your graphics card if you are using AGP slot
10. put back power cable 20 pins and 4 pins
11. Connect keyboard and monitor cable
12. Use screwdriver to shorten the power on pins
If it does not work than you should say goodbye to that motherboard and old technology that you are using and buy motherboard socket 775 or socket AM2 and new cpu and ram its cheap this days to have real dual core computer.
Jul 11, 2017 | Albatron PX845PEV PRO 800Mhz Motherboard
STREET ADDRESSS SCREEN BLANK
Try removing the memory card, then performing the problematic functions, then shut off the unit. Wait 5 minutes, insert memory card, turn on unit and perform functions again, see if it works.
Sep 08, 2008 | Fine Digital FineDrive 400 GPS Receiver
Jetway MiniQ 765Twin (miniq765twin) Barebone Logo
74 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
