Question about Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
My Dell 1600sc suddenly stopped sending a video signal. Upon reboot, everything appears to power up, yet I am still not receiving a video signal to troubleshoot problems. I added a PCI video card with no change. The 1600sc is network attached, yet I can not map a drive to the 1600sc from another computer, so I suspect it is not booting all the way up. I am not getting any system beep codes either. I verified that the monitor, keyboard and mouse were all okay using another computer. Upon inspection inside, all cables and connections are tight. The only thing that looks out of place is a blinking green led in the lower right side of the motherboard when powered up, and it stays blinking until it is powered down. The tiny number next to this led is U23.
Many thanks for any help.
  • 1 more comment
  • Brian_L Jan 08, 2008
    I tried this with no change. I even tried changing the power supply with no affect. I reseated all of the cables, the Memory card and the CPU likewise with no change. I still think the blinking green led on the motherboard is trying to tell me something, but have no way of telling what it means. The system does appear to go through some sort of boot cycle and then completes with two quick beeps and then the green led I know that when I opened the server that there was quite a bit of dust that I cleaned out, but haven't dusted the back side of the motherboard. Does anyone have any opinion if dust could cause this problem? That's my next thought other than going the expensive route and start changing out the CPU.
  • Brian_L Jan 10, 2008
    Himm --- clear the CMOS settings. I'm not sure how do do that. It's been a while since I have updated BIOS. I'm not by the server right now, but I seem to recal Dell shipping a CD with the BIOS on it. Can you tell me the steps I need to perform to reset this --- would sure be simplier with a monitor, as I can't check boot sequence, or anything?
    Thanks for your help !!!!!
  • Daone May 01, 2008
    Well I have a similar problem, however on my server It's a brand new mother board and processor. Nothing comes up on my monitor either. All the cables are plugged In real good and everything does power up, but nothing on my monitor. Also when it does power up there is no beeps at all, even if I disconnect all the drives there is no beeps. What else could it be.
I also have this problem with my Dell Poweredge 1650, integrated Ati Rage XL doesn't work. But when I add PCI graphic card, I get the video from it. Could integrated video be somehow disabled?
Posted on Apr 02, 2011
I have at this same problem. Its not the Bios, CPU, RAM or power supply. Its the mother board itself. I ordered a new mother board off of and my server works fine!
Posted on Jul 20, 2008
It seems that you cannot upgrade the video card on certain Poweredge Servers. Not sure how that is possible, but Dell probably did it becuase now these servers could be used for power user workstations - and repurposing doesn't give dell any more money.
Posted on Jun 17, 2008
Hi I have similar problem with my poweredge 1600sc.
When I power it up the video image doesn't come on until I press the reset buttom once and everything start working as normal.
No Idea what the problem could be.
Posted on May 03, 2008
The beeping sound might be the the caused of wrong memory module, fan not plug in right, power supply wires not connected properly. i work in a company where i have to maintained 67 Dell 1600sc servers.
Posted on Apr 13, 2008
  • 131 Answers
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Posted on Jan 03, 2008
  • M Karthikeyan
    M Karthikeyan Jan 09, 2008
    Dust i not a problem, once you switch on the power,
    the system, the processor and rams are checked, the beep tells us that the ram is ok, then the bios posting takes place, once the bios posting is done the control goes to your hard disk from where the os takes control and so on.
    analysing your problem, you are having problem with the bios posting, because after the beep the system does nothing,
    do you see any display on the monitor, if you dont see anything, then you are having problem with the bios, hence clear the cmos settings.
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Xbox 360 cant output a video signal anymore, first noticed a problem when the video screen began turning green thought it could be a defective cable but upon purchase of a new one still got no video...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Feb 23, 2010 | Microsoft Xbox 360 Console
I have hooked everything up and the monitor shows " no signal".
are you using the onboard? video... or a seperate vid card? if it was working and then suddenly quit? the onboard vid chip is out! cant replace that either try adding a seperate vid card and reboot
Jan 13, 2010 | E-Machines eMachines Desktop PC
Abrupt loss of signal to monitor.
May be your Video card. Try a different monitor to see if it is working. If not you may need a new video card.
Nov 15, 2009 | E-Machines eMachines Desktop PC
DELL PowerEdge 1600sc - New motherboard no joy
Are you sure the new motherboard was of the same revision as the old one? Dell shipped 400FSB boards during the beginning of the 1600SC line and shipped 533Mhz boards during the end of the run. I would check the revision level of the motherboard to make sure it is compatible. If it's the same revision, I would start small and connect just one CPU and put the system at 512mb ram and see if that works. If this works, you can begin to add additional components as needed.
Good luck
Jun 19, 2009 | Dell PowerEdge 1600SC Server
Dell 1600SC Server - trying to install a video card
try repeatadely pressing delete on startup with the monitor cable attached to your onboard graphics socket but keep the new graphics card in. then you should go into the bios. change the graphics setting to your graphics car and then save and reboot. it should now work from your new graphics card
Jun 18, 2009 | Dell PowerEdge 1600SC Server
Blue screen
Simply change your Ram with new one.
Apr 08, 2009 | Computers & Internet
The right Channel is not working
hello if you are sure that you check everything, speaker,cables input signal.
if this pionner suddenly stops playing in one channel the most probable is in protection not burned so it needs service at repair shop.saludos
Jan 17, 2009 | Pioneer VSX-D811S Receiver
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Dell PowerEdge 1600SC Server Logo
1,080 people viewed this question
Alun Cox
