SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER WANT RUN. THE SHREDDER IS CLEAN, NO JAMS, SIMPLY NO POWER. SWITCH WANT TURN THE SHREDDER ON, NOTHING HAPPENS.
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
I have a 150MX Royal Crosscut Shredder and have found that at one end the plastic spacers have...
(More)
I have a 150MX Royal Crosscut Shredder and have found that at one end the plastic spacers have broken off on the top and bottom cutter wheels and paper has jammed around the wheels causing the inefficient function of the shredder. It jams on only 3 pages of paper. There is also another bottom spacer broken near the other end as well. Can these spacers be replaced? If yes, where can the parts be obtained?
I misplaced my user's manual and I overloaded my shredder. I have tried reverse and forward, but it...
(More)
I misplaced my user's manual and I overloaded my shredder. I have tried reverse and forward, but it is still jammed. What do I do???
The needed gear is the plastic gear that feeds off the motor shaft. A paper jam caused the motor...
(More)
The needed gear is the plastic gear that feeds off the motor shaft. A paper jam caused the motor shaft gear to chew a divot into the plastic gear.
