Denon ADV 700
Hi
I have a Denon ADV 700 and when I play a CD it produces no sound. The counter works properly but no music. Do I have the set up wrong or do I need to have a CD player connected in order for it to work. I pressume it is capable of playing both DVD's and CD's. When I select CD as the playing option it automatically defaults to DVD when I press play.
  • Erik1974 Nov 29, 2008
    Same problem over here... there's no sound when I play a cd, neither through the surround set, nor through the headphones...
    Top Expert:
  • Audio Player... Master
  • 12,962 Answers
If counter is running the disk is being read. Check your settings and/or wiring.
Posted on Sep 17, 2017
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
SOURCE: cd player not playing some cds: denon cd player ucd-77
It's not the cds that are the problem as they work in other cd players. Its seems to be the denon cd player itself that doesn't seem to be reading the cds.
Binap
Posted on Jan 31, 2008
Mark_Webber
  • 472 Answers
SOURCE: BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Posted on Apr 09, 2008
VOTIT
  • 2071 Answers
SOURCE: Denon adv-500sd will not play discs!!
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jan 11, 2009
  • 16 Answers
SOURCE: Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Posted on Feb 06, 2009
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
Jan 31, 2009 | Denon Dns1000 Table Top CD Player CD...
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
Denon adv-700 - Mech error
try to disconnect your system from power and connect it again.
Sep 06, 2008 | Audio Players & Recorders
87 people viewed this question
 Grubhead
Grubhead
