Canon PIXMA iP90 Mobile Printer
Problem for Canon PIXMA iP90 Mobile Printer
When ever I request to
By shickey2_1 on Oct 23, 2009
When ever I request to print. It pops up that the waste ink container is full and to press reset. How can I fix this so that it doesn't keep doing it?
Comments:
Oct 23, 2009
- The solution was very helpful. Thank the GURU
Best Solution
posted on Oct 23, 2009
Very Helpful)
57 varieties
Rank: Guru  Canon Computer Hardware  Expert
Rating: 88%, 587 votes
The waste ink absorber or "drain pack" is the large sealed plastic part that fills much of the rear end of the printer. It's either black or beige and has several vents on the top, through which you can see a fibrous material. That's where the ink ends up, and what can become full. It can be replaced, but there's no realistic way to empty or clean it as it is a sealed unit. These can be obtained from most ink sellers and cost around $15 / £10 / E12 each.
The purge unit (HP call it a service station) is a complex little mechanical assembly that sits under the carriage at the right end of the printer. It has a small rectangular hard plastic pad that collects ink from the print head during purging, and stays moist to keep the print head from drying out. This does NOT fill up, and shouldn't be fiddled with unless it's covered with cat hair. Ink that is deposited in the purge unit is transferred into the waste ink absorber.
There are a few other foam strips and sponge pads along the sweep of the carriage that also do not realistically need maintenance and never really fill up.
Once it has been replaced do the following if the error does not clear.
Reset the Error
Disconnect printer from AC power
Press and HOLD the POWER button, and connect printer to AC power
Release the POWER button
Press the POWER button again
Popular Solutions for Canon PIXMA iP90 Mobile
Questions and Unsolved Problems for Canon PIXMA iP90 Mobile
Do you recommend Canon PIXMA iP90 Mobile Printer?
Answer
Answer
I am trying to calibrate a cannon ip90 printer
Answer
my cannonip90 came with my computer when I bought it and I had to do a recovery of my computer and... (More)
Answer
Los busco Driver para meterla a mi compu y no puedo
Answer
my cannon prints ok in black but not in colour. The colour which comes out is wishy washy and... (More)
Answer
when i print, my printer dialog box on my computer says that the printer is downloading... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
