I have a HP ZD8000 laptop, which wont turn on. When I press the on button the LED's light up, and sometimes the fans begin to fire up, but only for a split second. When I press the on button whilst both the battery is connected and the power supply is aswell the charging LED goes out when I press the on button and I have to remove power supply and reconnect for the charging LED to come back on again.
Try just the power supply fromt he wall to the laptop without the battery inserted. If it comes on and then turns off, you probably have a bad power connection. DC power jack may be bad and would need to be replaced or re-soldered.
-=/ Daft Tech /=-
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion zd8000 PC Notebook
My laptop screen has just developed a yellow line down the full screen. At first it was...
(More)
My laptop screen has just developed a yellow line down the full screen. At first it was intermittent, but now appears to be permanent. I have re-booted & it is still there??
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into...
(More)
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into hibernation and now it will not turn on at all
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list...
(More)
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list just disappear and are not to be found.
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple...
(More)
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple of weeks has made its way down the screen. This is a new laptop and I haven't taken it anywhere and handle it with great care. Any ideas as to what I can do other that ship it back to Toshiba?
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success....
(More)
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success. color is off and picture distorted
