Try replacing the power cord, if the problems still persist, check the wall outlet, if it's in good shape, check for the battery, is it full or empty.
To check the battery, try to switch on your laptop without plug in your power cable to outlet.If the laptop's on, you should replace your charger unit for the laptop, that's the cause.
My laptop screen has just developed a yellow line down the full screen. At first it was...
(More)
My laptop screen has just developed a yellow line down the full screen. At first it was intermittent, but now appears to be permanent. I have re-booted & it is still there??
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into...
(More)
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into hibernation and now it will not turn on at all
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list...
(More)
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list just disappear and are not to be found.
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple...
(More)
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple of weeks has made its way down the screen. This is a new laptop and I haven't taken it anywhere and handle it with great care. Any ideas as to what I can do other that ship it back to Toshiba?
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success....
(More)
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success. color is off and picture distorted
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
