Question about Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter
Belkin USB wireless just up and quit working?
Hi, I was using the Belking wireless USB and It was working just fine for months and months then one day it just up and quit working on me,when we try to reihnstall it, it says theres something missing on the CD it came with,have any suggestions? Thanks.
    Genius:
  • 1,601 Answers
Posted on Dec 31, 2007
I had to reset my router because I forgot my security key. Now the wireless isn't working. The light is off and I can't connect to it with my laptops. What happened and how can I fix it?
It is possible that since your reset your router that the settings is more likely to be reset as well then you will have to connect using an ethernet cable direcly from the lptop to your router to turn on the wireless capability of your Belkin router.
You will need to get your router's Default gateway to get in the router and turne the wireless capability on it. Most probobly the IP address of your Belking would be 192.168.2.1 type this in IE on the address bar then press enter this should lead you into the router "Belkin" make sure that your are connected using ethernet from the laptop to your Belking router to be able to do this.
Feb 21, 2011 | Belkin (F6D42304) Wireless Router
I have a Belkin G wireless router and everything was working great until last night. Now if I run my wired laptop through it I can't connect nor am I picking up a wireless connection. I have uplugged and...
Thisis a common problem I have with Belking Wireless G and find the best solution is to remove the software and of the course reboot then reinstall.
Regards
GeWiz.
Dec 10, 2009 | Belkin Computers & Internet
Password on my belking
ya want to put password on my belkin
Feb 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
Not satying connected
Try using the Window built in connection utility. Open up the belkin softwar, click on the 3rd tab and select, use windows. See if that works
Jun 04, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
May 18, 2008 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Logo
195 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
